Tire warning
Old Nov 28, 2011 | 06:24 PM
CPTAHAB's Avatar
CPTAHAB
Default Tire warning
Lot of rain cooler temps today in Tampa. On drive home got Service Tire warning. Blinking tire display and "XX" for pressure reading. Tire looks fine feels solid, etc. Malfunction???
Old Nov 28, 2011 | 07:36 PM
cell6ida's Avatar
cell6ida
Try reprogramming the tire sensors. Worse case you may need to replace the one that is not getting a reading.
Old Nov 28, 2011 | 07:59 PM
saplumr's Avatar
saplumr
Better use a pressure gauge. Run flats can have 0 pressure and still look and feel soilid.
Old Nov 28, 2011 | 08:26 PM
FloydSummerOf68's Avatar
FloydSummerOf68
XX means the sensor is going bad, it doesn't mean low pressure.
If your car is an older model it's likely the batteries are just going out on it and you'll need to get a new sensor for that tire.
Old Nov 28, 2011 | 08:50 PM
saplumr's Avatar
saplumr
Defective TPM will give a "Service tire monitor" in DIC.
Old Nov 28, 2011 | 09:21 PM
TripleAstyle123's Avatar
TripleAstyle123
I had all of my Tire pressure sensors read erratically and very low or nothing at all. I replaced my battery and everything was perfect again. BUT- I also noticed the engine would turn and extra time or two before starting up due to the battery being weak.
Old Nov 29, 2011 | 08:07 AM
FloydSummerOf68
I've had 3 sensors go bad or need reprogramming and result in reading "XX"
I have never seen "Service Tire Monitor" ever.
Old Nov 29, 2011 | 08:35 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
CPTAHAB,
This could mean a few things. It sounds like an issue with your TPS. I'd recommend checking it out with a gauge to make sure your car is safe to drive. Then, take it to the dealership and have them check out your TPS. Let me know if there's anything I can do to help.
Chevrolet Customer Service,
Justin
Old Nov 30, 2011 | 12:46 PM
Tampa Tuning's Avatar
0Tampa Tuning
Former Vendor
St. Jude Donor '12
Default Corvette Tuner in Tampa
How old are your sensors?
One could be heading south. Mine were slow to repond before I replaced them.
www.TampaTuning.com
To Tire warning
