Oil temp too high?
Old Nov 30, 2011 | 10:09 PM
twofeet020's Avatar
twofeet020
Default Oil temp too high?
2011 Grand Sport Convertible and I installed headers yesterday. Driving around on the highway oil temps hover around 228 degrees...is that normal? I never paid attention to the oil temp prior to header installation. Thanks guys!
Old Nov 30, 2011 | 10:17 PM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Yep, perfectly normal. Were you driving around on the street? or the highway. If it's around town, that's definitely within spec. If you were driving on the highway at 70+ mph, I'd say it's a tad high, but nothing too crazy. My car stays at 204* when driving to work at 80mph.
Old Nov 30, 2011 | 10:25 PM
twofeet020's Avatar
twofeet020
I drove probably about 30 miles on the highway with outside air temp of 72 and between 220 to 228 of oil temp near the end of my trip
Old Nov 30, 2011 | 11:40 PM
1Corvette's Avatar
1Corvette
When cruising after the engine is fully warmed up (can take 20 - 30 minutes) your oil temp should run about 20 degrees above your coolant temp. If you have the OE thermostat, I would consider your oil temp perfectly normal.
Old Nov 30, 2011 | 11:57 PM
jon6.0's Avatar
jon6.0
I have a base with no oil cooler and my highway temps are 215-220F.
Old Dec 1, 2011 | 01:35 AM
Jawnathin's Avatar
Jawnathin
Gosh, in a way I'm a bit envious of these temps.
I have a Z with an oil cooler and it takes forever to get up to temp. I have to keep it in lower gears than what I'd normally cruise around in to try to get it warm. By the time it warms up, I'm already at my destination.
Old Dec 1, 2011 | 08:43 AM
twofeet020's Avatar
twofeet020
My coolant is at 189 when I'm on the highway and the oil temp at around 225ish...I figured the headers we're giving off more heat but just didn't want to be too concerned that those temps were going to be a problem
Old Dec 1, 2011 | 01:47 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
According to our retired oil engineer, 5W-30 oil is best between 190'-260'F if you are going to use full throttle. That's a generic number, not Corvette-specific.
The middle of that range works out to be 225', which is right where mine runs on the highway in summer. Of course, it goes up in a hurry once i do get on the throttle.
Old Dec 1, 2011 | 07:44 PM
thatonedude1's Avatar
thatonedude1
I would say that 225 is fine but seems to be a tad higher than most. I have a Z51 that has an oil cooler and I also have a 160 degree stat, and mine tends to be about 190-200 on the highway and 205 in town. I don't think the headers contribute much to oil temp, especially on the highway where the airflow carrries the heat out of the engine bay. In town, the headers may end up soaking the bay and bumping oil and water temps a few degrees.
Old Dec 1, 2011 | 08:39 PM
Olddudesrule's Avatar
Olddudesrule
I agree!. This is my first dry sump car, and it takes forever (relatively) to get the oil up to @ 140. I've only been driving it for about a month, but I've never gotten the oil higher than 165, and that was on a 75 degree day making a few runs up to 90 mph!
Old Dec 1, 2011 | 09:20 PM
mjcourt's Avatar
mjcourt
My 2011 M6 GS routinely ran around 195 around town ot on the highway. On the track it ran 220-240.
Old Dec 1, 2011 | 11:16 PM
Presidentialpawn's Avatar
Presidentialpawn
230 in trafic my 2011 GS
Old Dec 2, 2011 | 01:43 PM
Ragtop 99's Avatar
Ragtop 99
cover the oil cooler and you'll warm up faster. Doesn't sound like your daily driving needs the oil cooler.
Old Dec 2, 2011 | 04:57 PM
JoesC5's Avatar
JoesC5
The oil cooler sits right in front of the condenser which is right in front of the radiator. Block the oil cooler and you are also partially blocking the radiator. Might not be a problem at 30 degrees ambient, but at 70 degrees, might cause coolant overheating.
Old Dec 2, 2011 | 10:18 PM
fnsblum's Avatar
fnsblum
Engine load, RPM etc. determine oil temp. The larger volume of oil in the dry sump engines helps to hold the temp down also. Later! Frank
Old Dec 2, 2011 | 10:34 PM
Olddudesrule
Good idea, and I hadn't thought about it! Thanks.
Old Dec 2, 2011 | 10:56 PM
Gearhead Jim
St. Jude Donor '13
The ideal situation would be to have a thermostatically controlled oil cooler, but that's complicated and can always develop problems of its own.
Next best would be to have a durable but easily-removable cover for the oil cooler. Take it off in Spring, put it on in Fall. Maybe someone already has done that.
To Oil temp too high?
