C6 Rearend Upgrades
Old Dec 2, 2011 | 11:53 AM
Taters's Avatar
Taters
5th Gear
Default C6 Rearend Upgrades
I'm about to put a ~575HP LS2 into my 07 and will be using it at the track quite frequently. I have a spare M6 trans and diff that I will be building up to handle this power and would like to get some input on what I can do to help bulletproof it. The car will see the track at least twice a month and needs to be able to stand up to hard launches with drag slicks. Thoughts? Suggestions?
Old Dec 2, 2011 | 12:03 PM
8850's Avatar
8850
PM Thesubfloor. He has a built tranny that has been holding up very well and a Z06 diffrential with additional weld that is necessary to prevent the housing from cracking.
Old Dec 2, 2011 | 05:08 PM
Red06Vette's Avatar
Red06Vette
I believe subfloor has an A6, taters stated he has an M6. My suggestion would be to contact RPM Transmissions and get their recommendation.
John
Old Dec 2, 2011 | 05:40 PM
Devilish34's Avatar
Devilish34
Contact forum sponsor Rick Kim RKT56... www.rkt56.com He'll fill you in on what you need. He did my C6Z diff in my 07 M6
Old Dec 2, 2011 | 08:19 PM
Gering's Avatar
Gering
Tolero Apto Victum
OP: Here are 2 sites to check out. http://rpmtransmissions.com/ & http://www.centurytransmission.com/home I have an A6 2.56 Diff from RPM and like it a lot. Good luck with your upgrades.
Old Dec 4, 2011 | 12:07 AM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
If you want the budget way, you would want to upgrade the main shaft to 30 spline and pinion gear to match. Upgrade all internal parts in the diff to C6 Z06 parts. If you have a higher budget, TR6060 and C6 Z06 is the bulletproof way to go. PM me if you're interested in a quote or the parts list.
__________________
Supporting Vendor
To C6 Rearend Upgrades
