10.8@126.4mph in my Cartek tuned NA bolt ons only C6
Received 2,054 Likes
Congrats again Marc!
Nah not at the moment, I really like the reliability/drivability of the car as it sits right now, I don't want to upset the balance too much.
http://www.youtube.com/watch?v=EeRZgx-iuUo
I too use to find that flashing it was quickest as well but more testing showed me that actually stalling it up a bit still gets me just a little bit better ET. This relatively tight converter only stalls up so high so I think I was leaving around the 1800-2200rpm range.
Do you not already have gears Marc? From listening to the video it sounds like the 3 to 4 about the 1/8 mile. Don't I hear three shifts and the last coming way before the finish line? My 2.73 barely shifts to 4th before the lights.
I do sort of see/hear what you might be talking about though, it does almost sound like the first shift happens not too far out from the tree but that's definitely not a shift, it might be some slight wheel spin or a bog of some sort.
This video of the other 10.8 pass doesn't seem to have that bog or delay in it, it clearly shows only two shifts :
http://www.youtube.com/watch?v=Cc_b5...eature=related
No, still has the stock 2.56s in it as Dennis had said, only two shifts in the 1/4 mile for me.
Didn't mean to indicated doubt, just trying to clarify. But yes the second video is indicative of your 2.56 gearing. Great running!
#33
#34
I noticed that as well, not just in the video but also as I was actually making some of those passes as too. I started out perfectly within the groove at the starting line/tree but then I'm like all over the track once I launch it for some reason LOL. I think I was just a little out of practice and also not quite that used to the consistent low 1.5x sixty foots so I might've let the car sway a little bit or maybe even overcompensated for it once I'd realized I was doing it.
I even wonder how many thousandths (or even a hundredth or two?) that I'd tacked on to my ET by doing that.
#36
#38
