radiator fan Question
Old Dec 5, 2011 | 07:23 PM
vaelon2007's Avatar
vaelon2007
Default radiator fan Question
I have an 05 and need to know if the fan is supposed to come on in accessory mode. Just got done reinstalling a new fan and fan control module and don't want to fill it up with coolant til I know for sure it will only come on if car is started or if it's supposed to come on in accessory mode.
Old Dec 5, 2011 | 10:41 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Since the fan is electric, what problem would it cause by the fan starting with no coolant in the system?
Old Dec 6, 2011 | 02:22 AM
Bill Dearborn's Avatar
Bill Dearborn
It will not come on if the control system doesn't see a need for the fan.
The ECM commands the fans ON under the following conditions:
• The engine coolant temperature goes above a calibrated amount.
• The engine oil temperature goes above a calibrated amount.
• The A/C pressure reaches a calibrated temperature.
• After the engine is shut OFF, if the engine coolant temperature at key-off is greater than a calibrated amount, or the A/C pressure is greater than a calibrated amount, the cooling fan is set to low speed. The fan will shut OFF if the temperature or pressure drops below a calibrated amount. The fans will shut OFF after 2 minutes, regardless of coolant temperature.
Bill
Old Dec 6, 2011 | 07:24 AM
vaelon2007's Avatar
vaelon2007
Bill, thanks for the great info. I'll fill it up and start it up and watch for the fan to come on!
To radiator fan Question
