Explain difference in Launch Control and Traction Control
Old Dec 7, 2011 | 11:53 AM
Rocket-J's Avatar
Rocket-J
Default Explain difference in Launch Control and Traction Control
Can anyone explain how they work. I have had traction control before.
I know I can turn it on and off. The Launch Control seems to be on all the time. I don't see any switches for it on my new 2012 GS. I don't see anything about it in my manual. Maybe I am blind. Thanks.
Old Dec 7, 2011 | 12:57 PM
mitchydkid's Avatar
mitchydkid
I don't have LC in my 08, but I love being the first to respond to a thread.
When using launch control, the car KNOWS you want to go fast. LC will allow some wheel slip and modulate your power to get the best launch it can.
Traction control, the car thinks you are losing control of the car and thus it dials your power WAY down and your car falls on its face instead of squirting forward at super fun speeds.
Found it in the 2011 manual, page 9-42
http://www.chevrolet.com/assets/pdf/...ner_Manual.pdf
Old Dec 7, 2011 | 03:44 PM
Rocket-J's Avatar
Rocket-J
Thank you.
Same page in my 2012 book. Funny, it is not in the index or preface.
I need to go try it out. Sounds exciting.
Too bad the automatics don't get one. Guess they just don't need it.
Hold that peddle on the floor and drop the clutch.
Quote: "The Launch Control feature will initially limit engine speed as the driver radily applies the accelerator pedal to wide open throttle. A smooth, quick release of the clutch, while maintaining the fully pressed accelerator pedal, will manage wheel slip."
Old Dec 7, 2011 | 04:12 PM
BEZ06's Avatar
BEZ06
Originally Posted by Rocket-J
....Quote: "The Launch Control feature will initially limit engine speed as the driver radily applies the accelerator pedal to wide open throttle. A smooth, quick release of the clutch, while maintaining the fully pressed accelerator pedal, will manage wheel slip."
You didn't quote the part that it's necessary to be Comp mode.
You also have to begin from a stop (not rolling at all), and the steering wheel must be centered/straight.
It doesn't say it in the manual (I don't believe) but LC also requires a "no-lift-shift". I believe that if you lift the accelerator pedal when shifting that it will drop out of the LC mode, so just keep the pedal-to-the-metal when shifting during your run.
Like it says in the manual, LC is intended for drag strip use. Your redline shifts in a base C6 comes out to something like this:
1->2 shift will be at around 55mph
2->3 at around 85mph
3->4 at about 115mph
A Z06 has a higher redline, and redline shifts will be about 10mph faster in each gear. Also, a Z51 has a little different gearing and will be slightly different.
Although the ZR1 has a 6500RPM redline, the redline shifts will be at Z06 speeds due to the different gearing.
Take a look at the great gear/speed calculator by forum member leres:
http://xse.com/leres/z06/calculator.html
Bob
Old Dec 7, 2011 | 06:53 PM
Rocket-J's Avatar
Rocket-J
Thanks Bob.
I was just saving time on typing. I did read the entire instructuions, and yes, it appears you flat foot it all the way through the gears.
I have a GS and the close ratio gear box is different than a standard
C6 box. 1st,2nd and 3rd are very close.
I have 1400 miles now. At 1500 I will do my first "Launch Control".
Old Dec 7, 2011 | 08:18 PM
BEZ06's Avatar
BEZ06
....I have 1400 miles now. At 1500 I will do my first "Launch Control".
Woo Hoo!!!!
Hang on and report back and let us know what you think of it!!!
Bob
Old Dec 7, 2011 | 10:26 PM
JoesC5's Avatar
JoesC5
Thanks Bob.
Don't mean to nit pick your post, but the GS has a wide ratio transmission(as compared with the base C6). Your gears are spaced out further then the gears in the base C6, not closer. Each time you upshift you will have a greater RPM drop then the base C6.
The Z06 has the same ratios as the base C6(but not the same transmission) but the ZR1 is the one with the close ratio gears.
Old Dec 7, 2011 | 10:58 PM
Rocket-J's Avatar
Rocket-J
Here are the splits.
GS- 1=2.97, 2=2.06, 3=1.43, 4=1.00, 5=0.71, 6=0.57
Base C-6 &
Z06 1=2.66, 2=1.78, 3=1.30, 4=1.00, 5=0.74, 6=0.50
ZR1 1=2.29, 2=1.61, 3=1.21, 4=1.00, 5=0.81, 6=0.61
All with 3.42 rear end. GS is lower out of the hole.
If I didn't state these correct, I am sure I will be corrected.
I thought I seen different numbers when I look before. I can't find the same source again. Have at it.
To Explain difference in Launch Control and Traction Control
