RHS heads
Old Dec 9, 2011 | 10:37 AM
articwhitec6's Avatar
articwhitec6
Default RHS heads
Is anybody running the RHS aluminum heads. Looking at a change on our ls2. Any help would be appr. I'm bone stock. Buying headers today and going from there.
Thanks,
Jeff
Old Dec 9, 2011 | 08:01 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
I've looked into those with not much info other than magazines.
I know that they are originally the DART LS heads and the consensus then was that the 205 needed work to make them work, but, the 225 was just OK
The Comp site at the PRI show didn't have any heads or info that I saw/found
I did see and talk to the folks from Texas Speed on their heads and the guys from AFR about theirs. Both have some nice heads on the blocks
Old Dec 9, 2011 | 08:06 PM
timd38's Avatar
timd38
I would just buy new LSA heads and have them CNC ported.
Old Dec 9, 2011 | 08:17 PM
edcmat-l1's Avatar
edcmat-l1
Go Trick Flow. Best cathedral for the price.
Old Dec 9, 2011 | 08:21 PM
Don 79 TA's Avatar
Don 79 TA
just pick a head to work within your specs
meaning you don't need a mega flowing head
you want to make sure you have high port velocity if you want to build the low end response
i'm toying with the idea of a set of 205 AFR heads
To RHS heads
