I'm looking to get a cam for my LS2 over the winter and I'm trying to figure out which one to get. My tuner suggested I get a shorter duration (low 220s) so I don't have to get a higher stall as well. I've been looking at Texas Speed cams since my tuner's shop is a dealer. I'm torn between these two:
I don't want a huge cam with a rough idle, just something that will give me a little power. I want to get some new heads as well, but I don't want to break the bank because I may not have the car for a really long time (maybe another two years?). Would the LS3 heads work well with one of the cams above? Any advice would be much appreciated .
both cams you mention would allow you to keep the LS2 castings (heads) and mill them for a bump in compression or use a thinner head gasket. I think you could have them re-worked by somebody like TEA, Livernois motorsports, Advance Induction etc for around $1300 and they would perform as well as the LS3 head or better with your setup. The cam choice depends on what you are looking for, staying with your stock converter? driveability concerns? are you planning on upgrading your stock converter to a higher stall unit?
I'd like a noticeable bump in hp/tq without sacrificing drivability and needing to install a higher stall. On the page for the 228/228 cam they say they recommend a higher stall, but I don't know if it's necessary or not.
As for the heads, what about the stage 2 heads from Livernois? Would it be better to go that route or get some AFR or TrickFlows? Like I said before, I don't want to brake the bank and I'm not shooting for 500 rwhp. My goal is to be close to 450 (I'm going to get a fast and Callaway honker soon as well and I already have Kooks headers).
My experience with Livernoise heads was not good. I got really crappy HP results with them, and when I questioned them about the outcome they said the heads were not very compatible with the cam profile I chose even though I provided them with the cam profile before buying the heads.
TEA and Advanced Induction tend to have the best results for ported stock castings I'd go with them if going in that direction. Good luck with your build, now is the time for getting all your info and deciding exactly what you want/need. It sucks finishing a build and being dissapointed.
I just looked at the TEA Stage 2 heads and they're about $200 cheaper and flow better than the PRC/TSP Stage 2.5 heads. However, with the PRC/TSP heads you get new cores, but it looks like TEA uses your heads. Any advice on what would be the better buy? I think it would be a net cost of $200-300 more for the TEA heads.
For what its worth, I haven't heard a single negative about TEA . That is who I would use in a future build.
