Coolant leak wierdness
Old Dec 10, 2011 | 11:09 AM
Dylan 93Z's Avatar
Dylan 93Z
Default Coolant leak wierdness
I have what I thought and still have thoughts is a water pump failure. Coolant seems to just pour out of the pump but I cannot find a weep hole or exactly where it is coming from. It looks like it is coming from the main portion of the pumo itself but like I mentioned there is noweep hole to see this leak or explain it. I dont think its a head gasket but do have suspicions it could be a pumo gasket. Any thoughts? I went to look at brand new pumo and could not locate a weep hole on it either.
Old Dec 10, 2011 | 11:59 AM
Dylan 93Z's Avatar
Dylan 93Z
I have read about an O-ring failure, where is this located?
Old Dec 10, 2011 | 01:40 PM
wallyj's Avatar
wallyj
http://www.texas-speed.com/p-218-gm-...asket-set.aspx
This is want the gasket looks like. Some refer to it as an o-ring since many LSX gaskets are this style.
Old Dec 10, 2011 | 01:47 PM
DSOMC6's Avatar
DSOMC6
It sounds like a water pump failure. The leak you describe is typical of one. The last one I replaced was made in Canada.
Unless someone R&R'd the pump recently and somehow screwed up the gaskets or torquing it in the proper sequence?
A new pump is fairly cheap (guessing about $225 at Part Taxi etc?). Install isn't difficult with just some basic tools. You'll also need coolant and (2) new gaskets.
Old Dec 11, 2011 | 10:19 AM
Dylan 93Z's Avatar
Dylan 93Z
thanks for the replies all, i am going to buy a new pump and go from there! thanks again!
Old Dec 11, 2011 | 10:36 AM
Surf2602's Avatar
Surf2602
Mine just went. Replaced under power train warranty. Same thing happened to me that you are describing
To Coolant leak wierdness
