Service Charging System Message
Old Dec 10, 2011 | 08:08 PM
madcadr's Avatar
madcadr
Default Service Charging System Message
Had the pleasure of having the "Service Charging System" message today on my 2008 c6 z-51 with 22k miles. Volts went down to 10.2 then, stayed around 11 steadily after that. Went to gym worked out, then after 2 hours - started the car and volts read 14 all the way home....
After searching through posts regarding this message I see it could be everything from aftermarket plugs (Mine are stock), loose connection on the solenoid, bad alternator, and some sort of "Noise" being caused that could 'Fool" the alternator sensor into not sending enough juice back to the battery.... What the he$$ !! Ha, Ha...
Remember the days of just a simple alternator test, replace, and drive-off and all was well? Guess not in this case - Sounds like some cars have gone back several times before the real problem was found...
Looks like it is back in the repair shop on Monday
Old Dec 11, 2011 | 06:46 AM
taken19's Avatar
taken19
Track Junky
Do you have any mods to the car? Like you said, many times its a combo of cam and aftermarket plugs that make this happen (like me).
Old Dec 11, 2011 | 09:35 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Since your plugs are OEM, look at the battery connections first and insure they are clean and tight. Next is the starter solenoid connections as this is where the alternator meets the battery. Do not forget its electrically hot down there.
Old Dec 11, 2011 | 11:14 AM
madcadr's Avatar
madcadr
Thanks.
The battery connections are very tight and clean. The battery was new last year from dealership.
The car is bone stock except for aftermarket stereo system I had installed over 1-1/2 year ago - Never had a problem with that though.
I will let the techs check out the solenoid connection - It has to go in on Monday for a few trim pieces anyways - So, they can throw it on a lift and hopefully find something "Easy" to fix. I would hate to hear that it is the alternator with only 20k miles on it...
Will let you know - Thanks for the replies.
Old Dec 11, 2011 | 12:54 PM
vetehead's Avatar
vetehead
Originally Posted by madcadr
Thanks.
Good luck...and make sure they lift it right!!
Old Dec 11, 2011 | 09:49 PM
VET4LES's Avatar
VET4LES
Your battery could be bad also. New batteries can go bad so make sure it is load tested.
Old Dec 11, 2011 | 11:32 PM
Gering's Avatar
Gering
Tolero Apto Victum
OP: Here are some threads for you to look at.
http://forums.corvetteforum.com/c6-t...ng-system.html
http://forums.corvetteforum.com/c6-z...post1579448383
Good luck & let us know what they find.
Old Dec 13, 2011 | 11:32 PM
madcadr's Avatar
madcadr
YEP - You were right - Bad cell in battery...
Here is the thing:
The battery was replaced under original warranty 13-14 months ago.
Now, I am under my extended warranty where batteries are not covered.
There is only a 12k 12 month warranty on batteries if they were replaced under original warranty - However, if you just walked in and bought one off of the street - It comes with a 5 year warranty...... Go figure.....
All I know is - I am not paying for a battery after only 13-14 months and 5k miles... Santa better own the dealership - Cause I am taking my stocking to them tomorrow.... Ha, Ha...
Old Dec 14, 2011 | 10:17 PM
madcadr's Avatar
madcadr
UPDATE:
Battery has dead cell - Dealership said loose stereo wire on battery terminal PROBABLY caused the drain and dead cell. However, stereo shop said if it was loose then my stereo would have cut in-and-out. Never had problem with the aftermarket stereo.
Here is the KICKER: They said they HAVE to REPLACE the STARTER as well.
So, my stereo works fine but supposedly caused the bad battery - However, starter needs replaced.... Hmmm.
It would seem to me (Just an average idiot) that things point MORE towards the starter causing the drain and bad battery - So, Why am I having to pay for the battery? My GMPP plan that I bought should cover the battery since the starter is being replaced. Why can they just say: "It's not the bad starter that caused it - It is something else unrelated..." Just because an idiot tech has an opinion about what caused it?
Any advise?
If not, oh well, just pay for the battery and move on I guess. Life is too short to argue over a battery...
Old Dec 15, 2011 | 07:44 AM
dgrant3830's Avatar
dgrant3830
I tend to have serious doubts that the starter is bad. Ask them to prove it to you.
Old Dec 16, 2011 | 08:07 PM
vetehead's Avatar
vetehead
Old Feb 24, 2012 | 10:07 PM
Vital Velocity's Avatar
Vital Velocity
St. Jude Donor '11
So if it's a heads and cam car, what plugs are safe to go with it to try to eliminate the service charging system message
Old Feb 24, 2012 | 11:15 PM
Gering's Avatar
Gering
Tolero Apto Victum
I have been using http://www.briskusa.com/ with no problems.
Old Feb 25, 2012 | 04:02 AM
taken19's Avatar
taken19
Track Junky
Originally Posted by Vital Velocity
So if it's a heads and cam car, what plugs are safe to go with it to try to eliminate the service charging system Philstireservice.commessage
The stock plugs have been proven to work many times.
Old Feb 25, 2012 | 03:09 PM
Vital Velocity
St. Jude Donor '11
Well did the plugs ( which if I remember doing them on my c5 was much easier on the c6)..... Previous owner had ngk tr6 in there......took them out and put in factory....drove around with no service charging system warning yet
To Service Charging System Message
