oil gauge not working
Old Dec 13, 2011 | 12:37 PM
Wicked65's Avatar
Wicked65
Default oil gauge not working
07 Z51 Coupe. Oil pressure gauge just stopped working. Digital one just reads XXX. No knocking, no noise at all from engine. Any suggestions on where to start looking? Where is the sending unit at? (never messed with a chevy before)
Old Dec 13, 2011 | 01:32 PM
RicK T's Avatar
RicK T
It's behind the intake manifold on the driver's side. "Usually" when they go bad they show max pressure (80 psi), at least by design they're supposed to. So obviously you need to make sure there isn't a pump/delivery problem. Here are a couple threads to help, one with a link to a DIY method of getting to the sender without removing the intake manifold.
http://forums.corvetteforum.com/c6-t...-location.html
http://forums.corvetteforum.com/c6-t...e-reading.html
