rotors warping
Old Dec 16, 2011 | 12:17 AM
adamb1226's Avatar
adamb1226
Cruising
Default rotors warping
i have a 2008 m/t non z51 package.. i have been feeling the brakes pulse at speeds around 70 and when i am coming to a stop as i press the brakes.. what should i do??? thanks for any help!!
Old Dec 16, 2011 | 09:19 AM
Tikiman12's Avatar
Tikiman12
you can replace the rotors or have them spun. If you remove them yourself your local auto parts store can spin them for you. Or most brake shops will will be able to spin them for you while they are replacing your pads.
Old Dec 16, 2011 | 11:14 AM
BEZ06's Avatar
BEZ06
I hold the same point of view regarding "warped rotors" that you can read about in this StopTech technical report - click on the link below to read it:
The "Warped" Brake Disc and Other Myths of the Braking System
Take a look at the StopTech White Paper main page to read many more very good articles on your brakes, including fixing your problem by running an aggressive race pad to abrade down the uneven pad deposits that are causing your problem:
http://www.stoptech.com/technical-su...l-white-papers
Just MHO, YMMV!!!
Bob
Old Dec 16, 2011 | 03:52 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
The rotors are probably not warped. You likely have brake pad material build up on the rotors.
I'd try scuffing up the rotors with 80 grit garnet paper (not sandpaper) to cut off the built up pad material.
Tom
Old Dec 16, 2011 | 05:58 PM
adamb1226's Avatar
adamb1226
Cruising
Well I think this was a wasted post due to the fact that I couldn't see the inside part of my tires and noticed they have warn pretty much to the end of their life. I replaced the tires that I had on the car which were Goodyear f1 gs2 run flats with Nitto invo's. That fixed it all. They were just way too warn out and out of balance. Thanks for the suggestions though.
Old Dec 16, 2011 | 09:26 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Just MHO, YMMV!!!
Bob
Tom
So what's the point in GM giving a lateral runout spec on the rotors?
Have you never seen rotors 'warped' from improper torqueing of the wheels or having some people wash their wheels before the rotors are cooled and causing them to warped?
Living in the racing world may be cool, but in the real life world, warping does exist from something more than pad build up.
Old Dec 16, 2011 | 10:54 PM
Bill Dearborn's Avatar
Bill Dearborn
Actually it doesn't. Running on the track will subject the rotors to more abuse than anything a street driver can do. Much more abuse.
I haven't ever seen a rotor that is clamped between the wheel and the hub be warped by over torquing the lug nuts. Rotor run out can come about due to several things. Some of them are manufacturing run out that is out of tolerance, hub run out and uneven wear due to pad deposits that cause a section of the rotor to harden and wear differently than other sections.
If rotors warped because somebody washed the car when they were hot there would be millions of car with warped rotors due to driving with hot rotors in a hard rain with deep puddles splashing them with cold water.
Bill
Old Dec 17, 2011 | 12:40 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Bill
I've never had a "warped rotor". Watch a rally car go from glowing red rotors to crossing a stream and you'll realize you won't ever subject a rotor to the kind of abuse they live through. Their rotors aren't "warped", and neither are yours.
San
To rotors warping
