This seem right
Old Dec 23, 2011 | 11:45 AM
C7/Z06 Man's Avatar
C7/Z06 Man
Being its supercharged I would expect to get a little more in the first half of the track.
10 psi of boost "may" be to much for the OEM compression on pump gas unless you have alcohol injection or running race gas. One of the biggest reasons for poor performance on a blowned engine is to much boost, so I would see if your getting any detonation, etc. before you destroy the motor.
Old Dec 23, 2011 | 12:53 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by FASTENUF
I have a set of 17" MT DRs left over from my C5 days. Can I run those?
I will talk to my tuner and see if he can log some runs for me.
Yup, that would work for you. Anything we can do to help let me know.
Old Dec 23, 2011 | 03:37 PM
FASTENUF's Avatar
FASTENUF
I never posted it, but you guys have been great! Especially Matt, he answered so many question pre and post sale, not to mention during the install. Many times late at night
If my tuner can't get me where I want to be, a trip to Jersey in the spring doesn't sound so bad
Old Dec 23, 2011 | 07:05 PM
DaytonaFIC6's Avatar
DaytonaFIC6
Are you holding the 10 psi throughout the entire pass? On my supercharged car I would occasionally have an issue with the coupler getting loose and bleeding off boost right at the discharge pipe bc it was very hard for me to get my hands in there and get the hose clamp really tight.
Old Dec 23, 2011 | 11:49 PM
dicky's Avatar
dicky
good call, i seen a guy at the track a while back that seemed to have this same problem causing his et and mph to be way off
Old Dec 24, 2011 | 11:54 AM
FASTENUF's Avatar
FASTENUF
This is something I will have to check on and see. I tried to record my runs using my Aeroforce guage but it will not record and it is almost impossible to read the gauge going down the track. Atleast for me.
I talked to my tuner and we are going to log some runs after the holidays. 121 just doesn't seem right.
Old Dec 24, 2011 | 12:39 PM
FloydSummerOf68's Avatar
FloydSummerOf68
I hope you figure it out...you should have another 7-8 mph in there at least.
Old Dec 24, 2011 | 04:30 PM
GREENTAHOE's Avatar
GREENTAHOE
Is the belt holding? Any signs of slip? Was it street tuned as well as dyno tuned? From what I've seen the ECS kit has a ton of belt wrap, but it's a quick thing to check.
Old Dec 24, 2011 | 06:09 PM
DSOMC6's Avatar
DSOMC6
No, my local tuner did it for me.
I knew running on the stock runflats would hurt my e.t., but I did not think it would effect my MPH that much.
Here is how the time slips broke down:
Stock--- S/Ced
60'--- 2.089 --- 2.074
330'--- 5.488 --- 5.186
1/8 --- 8.254 --- 7.747
MPH --- 89.26 --- 96.68
1000 -- 10.602 --- 9.932
1/4 --- 12.559 --- 11.783
MPH --- 115.45 --- 121.65
2+ second 60'
You'll pick-up .5 easy with a decent set of tires right there.
I'm gonna venture to say the loss of traction and inability to launch at a decent rpm is killing your et and mph. Not to mention the rf's are more than likely spinning near/at the top of the power band as well.
