Another wobbly Harmonic Balancer
Old Dec 22, 2011 | 02:42 PM
BeetleBailey's Avatar
BeetleBailey
Default Another wobbly Harmonic Balancer
My 06 Coupe with 20,000 miles has the wobbly harmonic balancer.
Took it to the dealer for warranty repair (I have GMPP).
Service man says although it does have some wobble it's not bad enough to replace "yet".
Said we'd have to wait for it to get worse.
Mine is JUST like this one on youtube:
http://www.youtube.com/watch?v=XrYo7...ature=youtu.be
Looks like about 125 thousandths to me. (about 1/8th inch runout.
The bolt is tight and it doesn't look like the balancer has moved, it's just the outer ring (inner ring that attaches to the crankshaft is running true) that is wobbling.
I'm very concerned about it and feel as if it is ADDING vibration back thru the crankshaft instead of absorbing them.
Very dissapointed they won't change it.
What do you guys think I should do?
Old Dec 22, 2011 | 02:59 PM
taken19's Avatar
taken19
Track Junky
Talk to their service manager and tell him the potential consequence and their liability if they DON'T change it. It would be a much more expensive repair if it let go...
Old Dec 22, 2011 | 04:18 PM
BeetleBailey
I'm, looking here on the forum for the factory spec. on runout.
There is also a procedure here on the forum for testing the runout (dial indicator against the pulley rear most rib, turn the engine by hand and measure it. After removing the spark plugs , etc, etc.
I have a dial indicator and can check it myself.
Anyone know the max. acceptable runout specification ?
Anyone have a link to the thread with all that information on checking and replacing the HB ?
Thanks in advance, guys.
Old Dec 22, 2011 | 04:29 PM
DSOMC6's Avatar
DSOMC6
It wont harm the engine just having some runout...well unless it lets go..then it could do some damage. I'd keep the documentation from the dealer showing you did advise them of the issue.
Old Dec 22, 2011 | 04:38 PM
8850's Avatar
8850
That's not .125 (1/8") runout. Probably not more than about .010. That amount is acceptable.
Old Dec 24, 2011 | 11:29 AM
swvalleyguy's Avatar
swvalleyguy
with 8850. The one shown in video doesn't have a horrible amount of runout. I would guess it would run another 200k miles and wouldn't lose too much sleep. But if you are the kind of person who likes to be safe its a simple matter of using dial indicator to get baseline measurement and then check in say, another 5K miles and note any change.
However, the balancer is really a dynamic device and the runout you would measure using dial indicator would be different when running. The optical/visual method of comparing runout to a known size of gauge might be the best approach and you could play the video frame by frame and compare movement with gauge size. This is low $$ approach.
Old Dec 25, 2011 | 07:54 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
that vidoe doesn't look too bad, but if it bothers you I would replace it with a high quality ud pulley...ATI would be my first choice.
Old Dec 25, 2011 | 08:41 PM
speedraider's Avatar
speedraider
fill out your profile, so people know where you live. Maybe someone near you can guide you in the right direction
To Another wobbly Harmonic Balancer
