A6 Cam Install - Need Higher Stall?
Old Dec 22, 2011 | 09:49 PM
dcvickers's Avatar
dcvickers
Default A6 Cam Install - Need Higher Stall?
I'm close to pulling the trigger on a heads/cam package from TSP, but I really don't want to have to get a higher stall as well. How large of a cam can the stock converter handle? The cam I'm looking at is 228/228 (228R), but I can go a little smaller (224/228 or 224/224) if it means I don't have to get a higher stall. Any advice?
Old Dec 22, 2011 | 10:34 PM
C7&7's Avatar
C7&7
You will be fine with the 228/228. I have seen 228/232 cams without stalls. All in the tune.
Old Dec 22, 2011 | 11:02 PM
dcvickers's Avatar
dcvickers
Would it even be worth it though? Is it going to be a pain to drive?
Old Dec 22, 2011 | 11:04 PM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
it really depends on the tuner, and the cam... a 228r you likely want a stall simply for the fact A) it maybe be a little lazy in the lowend (slightly), b) it may want to push though the brakes a tad at stoplights because of the raise idle speed... that all being said with a proper tune you shouldnt have no other driveability issues
Old Dec 22, 2011 | 11:16 PM
dcvickers's Avatar
dcvickers
So would the 224R be better in the low end? I don't need something with outrageous numbers. I just want something fun to drive on the street that is well-mannered (the chance of me taking it to the track are slightly less than never ).
Old Dec 23, 2011 | 01:18 AM
FloydSummerOf68's Avatar
FloydSummerOf68
A converter would be more fun on the street than a 224R cam.
I don't understand why so many people with autos are so against converters. It's quite literally one of the best mods you could do
Old Dec 23, 2011 | 01:38 AM
dcvickers's Avatar
dcvickers
I'm not against a converter, it's just something that I can't/don't want to do on my own so I'll have to pay for the converter and the install price.
Old Dec 23, 2011 | 08:54 AM
ls1wolf's Avatar
ls1wolf
great thread. There is little information about how big you can go on a cam without a converter.
Looks like 228 232 with stock stall is the largest?
Any more?
Old Dec 23, 2011 | 05:18 PM
dcvickers's Avatar
dcvickers
Any more?
I agree. Can anyone else give any insight into this question? I know some people may have high 220 or even low 230 duration cams with the stock converter, but how does it drive? Is it even worth it?
Old Dec 23, 2011 | 05:20 PM
C7&7's Avatar
C7&7
A good friend of mine had a 234/240 615 ish lift cam in his C5 with a stock converter. It ran just fine. Idled a little higher at like 1000 rpm but it ran fine. He did eventually add a 3200 stall though.
Old Dec 23, 2011 | 06:26 PM
phatman's Avatar
phatman
PM AndrewZPSU. He may have the exact cam you are looking for. He raised his comp and is running a small cam with stock stall. He runs 10.9s at 130 with the stock stall. I've gone for rides in his car and there is no stalling or hesitation. I am going with a slightly bigger cam, but I am going with a 3600 stall. If Andrew added a stall, he would easly run close to 10.5s.
Old Dec 23, 2011 | 06:58 PM
firefighter813x's Avatar
firefighter813x
I have a 2006 C6 with AFR 205's and a 224/224 115lsa with .6xx/.6xx lift with the stock converter. It drives normal to the average person. I can tell that it barely wants to push through the brakes at stoplights but it's something that most people wouldn't notice unless I point it out. I have a 3600 rpm FTI converter in my garage that I'm going to install soon.
I have 3.31 gears so it might help out versus stock gears...
Old Dec 23, 2011 | 11:03 PM
mitchell c's Avatar
mitchell c
I could not agree more. Excluding NOS a good converter is one of the best mods you can do on an A4 or A6. Especially if you're going to add a high performance cam.
Old Dec 24, 2011 | 12:07 AM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
You can get a custom built & tuned converter with very good street manners
or
if you decide on a cam, the idea is to match the cam to the comverter the 228 could use a converter because it may need a bit of help on low end (or the correct gear will also help if you don't want a converter) while the 224 would is possibly ok without a converter.
You use gearing or a converter to make up for the change in the power band due to the cam change
While Andrew has gone 10.9s in his LS3 I have gone 11.2 in my LS2 without a cam and just a 2800 stall converter & bolt ons. So there is always more than one way to go fast
good luck
Old Dec 24, 2011 | 02:53 AM
LS1LT1's Avatar
LS1LT1
Andrew also has some mild cylinder head work done as well, though I'm not sure if that would make the stock converter more street friendly or even less.
Old Dec 24, 2011 | 06:57 AM
TorontoC6's Avatar
TorontoC6
Depends upon how you use your car.
If you do HPDE's, the higher stall converters create more heat in the transmission and can limit time on track.
If it's for street and drag, then a converter upgrade is definitely the way to go. If you are adding a higher stall speed converter, consider upgrading your transmission cooling if you are going to be doing a lot of passes, live in hot climate, or spend too much time stuck in traffic.
Old Dec 24, 2011 | 09:41 AM
FloydSummerOf68
It depends on the converter.
The Yank 3200, that I complain about oh so often, does not produce enough heat in Houston (100+ in the summer) to warrant a cooler.
If I tracked it more often I'd get an external cooler, which is only what...50 bucks?
For street driving I wouldn't worry about the heat, but I would for track days.
To A6 Cam Install - Need Higher Stall?
