Broke my 08 Differential Case, What all to make a 08 Z06 Diff. work?
When I broke the differential case I also broke the output shaft in the Transmission, So I know that is getting changed also... Will everything else bolt right up of what?
I've already got a 08 z06 differential, I have the 300m hardened output shafts that I'm going to put in it out of my other differentia. I'm also gonna put the z06 mainshaft shaft in my trans. I was just wondering what else I had to have to make it work, like if it would bolt in to my cradle and stuff...
Former Vendor
The Z06 differential will bolt right up with a 30 spline Z06/GS 30 spline mainshaft upgrade to your current transmission. You will need to remove the rear pump assembly and the heat exchanger from the Z06 differential and install a base rear cover and plug the additional hole. We have the required plug that you will need and can provide you with a rear cover gasket as well.
That's a lot of RPM to launch these things. You can get a 1.60's just launching at 3k.
Been there, best of luck getting it back out to the track!
that was 4k rpm.... just some trail and error... that one was error.... Oh well... it probably wont go to the track very much...lol..... I meant to slip the clutch a little more, but it didnt work...oh well...
The car is a stock short block LS3.... It had 26x11x17 et streets on it....
Yeah its not stock, lol... It had an ECS Novi 2200 on 12 psi boost, H/C, Meth, RPS Twin Disc Clutch, The Differential didnt actually break, The output shaft on the trans broke, it wasnt a clean break, it broke at an angle and it walked over the other part and cracked my differential case... I had a DTE Brace on it and hardened shafts in the differential....
St. Jude Donor '08-'09
i did the same thing, but made it about 20 ft out of the hole. lucky for me, i did not break the housing,
Rick Kim @ RKT56.com is taking care of me with his Built Z06 TR6060 and Z06 rear with DSS shafts. plan to add a Carbon Driveshaft from DSS and an ECS trans/diff Brace.
I already had pfadt engine and transmount, with pfadt solid spherical bearing, some reason i credit that to letting it last as long as it did.
-Carl
p.s. also like to add, Twin Turbo, with RPS twin carbon clutch, Tick master cyl and MSD 2-step , BOOM! lol
-Carl
yeah I already got a stock z06 differential with 8k miles on it, gonna throw some hardened shafts in it, and put a 30 spline shaft in the trans and hope it lasts for a while...lol... My buddy did the same thing, he went to the track and it held up fine at the track hell he went a 9.98 on a 1.5x 60ft, and then he broke it on the street but it didnt bust his differential housing either...
