BOOSTA PUMP ISSUES Yes/NO/Maybe???
Come to a stop and RPMS still show good (as in all 8 are firing NO rmp drop) BUT.........black smoke out exhaust and IF you try to give it gas it simply boggs down more to a point of wanting to die...........its flooding NO DOUBT BUT the cause and cure?? CURE turn car off back on ASAP and issue goes away 100% till the next time!
Clearly engine is having TOO much fuel dumped in to it. I DON'T think it is blow bye as I have cleaned the MAF over/over and issue repeats itself BUT randomly.
FIX....again....(MOST random) Turn ignition off and upon (immediate re start) idle is 100% smooth NO black smoke and all is well until next random time this happens!
Something clearly re sets! SO after reading about the Boosta pump it talks about how at idle it will NOT dump fuel in unless........under boost/high rpm as if it did otherwise.........it would bog the motor down with too much fuel!
Exactly like MY issue????? SO how does one check to see IF boosta pump is kicking in when it should NOT be as it seems mine is doing??
Bad O2 sensor doubt it? MAF oiled up don't think so.
SO how does one find out IF a "boosta pump" IS malfunctioning allowing TOO much fuel to cycle in to the engine while IT IS at cruise and NOT under boost??
I am all but certain this may be my issue as the symptoms MY motor displays when this issue takes place is exactly what the description of this part says it will NOT allow to happen while operating correctly.
SO with it failing on occasion: MY car will show signs of this symptom of bogging down with too much fuel LIKE the boosta pump is operating TOO early NOT under boost .......this flooding the engine.
IF it were a oiled MAF I doubt just turning car off/back on would bring it back to a more lean condition and run normal as it does! O2 sensor again........how would turning car off/back on fix a bad O2 sensor??
ANY ideas on how to verify (that the boosta pump) is failing on occasions?? IS there some setting on it that may have to be adjusted to see if it can be corrected?
ALL before I buy a new one hoping..........my weird problem goes away for good with whole new part?
Thanks when able re any input
David
David
So based on the description of the boosta pump.......sounds like (if) it were mal functioning.........it would create a situation exactly like I am experiencing?
How could anything with the meth system cause my car to suddenly run way too rich?
IF meth was leaking (while not under boost).......could that cause car to run way too rich? Don't know......I am not too familiar with the set up.
Last weird thing is the "fix". Issue immediately goes away once I turn off the car and turn it back on! Back to normal NO signs of any too rich condition!
With a new motor coming I want to TRY to eliminate this mystery issue ASAP.
SO meth or boosta pump ANY additional ideas from anyone.........thanks for anyone's input here.
David
