2005 Steering Column Lock Issue
Old Dec 28, 2011 | 10:17 AM
C7&7's Avatar
C7&7
Default 2005 Steering Column Lock Issue
Does anyone know if the steering column lock on the 2005 effects fuel delivery? Would a failing SCL effect the engine from getting fuel? Like the car will turn over then fall on its face. Then after a few more tries the car will finally catch idle.
Old Dec 28, 2011 | 10:20 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Default No
Never had that issue when mine was failing.
Old Dec 28, 2011 | 10:21 AM
C7&7's Avatar
C7&7
Thanks Jim. Mine did this to me last night. Turned over and just fell on it's face. Finally caught idle after a few attempts
Old Dec 28, 2011 | 11:39 AM
Hoonose's Avatar
Hoonose
Nor mine, or any other SCL failure I've read about here.
Old Dec 28, 2011 | 04:28 PM
vette6500's Avatar
vette6500
SCL problem just refused to move the starter at all for me.
Old Dec 29, 2011 | 01:06 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Tim05C6Z51,
I'd recommend taking it to your local shop and having it checked out. I'd be happy to recommend a good shop or setup an appointment for you.
Chevrolet Customer Service,
Justin
Old Dec 29, 2011 | 02:21 PM
C7&7's Avatar
C7&7
Originally Posted by Chevy Cust Svc
Tim05C6Z51,
Justin
Justin,
Please PM me what shop you had in mind. I am curious which one you would suggest.
Thanks.
Tim
Old Dec 29, 2011 | 11:46 PM
taken19's Avatar
taken19
Track Junky
When the STL engaged for me, I got no starter engagement or engine turnover. Once issue cleared, no problems with starting. You may have 2 separate problems here.
Old Dec 30, 2011 | 09:13 AM
C7&7's Avatar
C7&7
Yeah I 100% agree. Just wanted to rule out this being a symptom of the SCL. I am chasing two different issues, however I think they both might be under wraps now.
To 2005 Steering Column Lock Issue
