Have the same problem many of the bretheren have - steep drive way - low front end on '07 C6. Did some reading here and saw there are "lowering" bolts at each wheel. Lowering in converse could mean raising as well. Called a local performance shop and he told me he could raise using the lowering bolts but we were only talking about a quarter inch or so - anything more and we have alignment problems. Anyone been there - done that? Comments? A quarter inch may not do it??
You probably have about 1.5 inches of total adjustability using the stock bolts. Where your vehicle is already set within that range is unknown, but I bet you probably have more ability to go higher than to go lower.
My Vette seems fairly sensitive to ride height as far as handling balance. I primarily lowered the front of mines because the factory ride height was WAY high, and dropping it down noticeably decreased understeer by making the front end stick better. If you're going to go higher and you like your current handling balance, you might want to think about raising the rear also. The bad part about doing that is that if you raise both the front and rear by the same amount, that's the amount of extra ground clearance you'll get. If you raise just the front, your air dam goes up by some amount that is greater than the amount of lift you get at the wheels.
You're absolutely correct. Have no idea if previous owner may have used bots to lower the car before I got it. Perfomance shop guy says he will be able to tell just by looking at it.....may run it down there and see what happens - I hate that rub going out of the driveway!!
BTW I have already cut the airdam down a little more than half - no cooling problems at all..
It took my car nearly 500 miles to settle to its final ride height after adjusting the bolts. When I first adjusted the bolts, I did a couple of turns, drove around, and nothing had changed. I did a couple of turns, drove around, and nothing had changed. Did a couple of turns, got a big drop, and then ended up having to go back up. It then slowly settled over a period of a few weeks to its final height. I then got another alignment. If you haven't had yours aligned, you might be surprised at how much variation you have from the factory. I had about half a degree of negative camber at the left rear and zero at the right rear, with combined toe in up front and combined toe out at the rears. It still handled well for street driving even with those settings, but after getting it aligned correctly, it's way better with better steering precision and feedback.
My experience also, except I was raising the car slightly instead of lowering. Took 200-500 miles for it to settle in properly.
Raising my car slightly did not seem to effect handling; but the increase was small, I raised both ends at the same time, and anyways I'm a klutz.
Jim, my front end was so high I think it was probably a combination of the lower center of gravity of the engine, plus less air getting under there, plus the downward rake changing the way the suspension worked. I like the extra downward rake for better handling and noticeably better fuel economy (I managed to get 32 MPG at a steady 70 MPH for a 120 mile drive), and except for more scraping I see no downsides. Well, at my advanced aged, getting in and out is a little more klutzy (hmm, sounds familiar) with the seat WAY down there. . .
Yes you can raise on the bolts.
Just keep the ride height at the OEM spec and you'll be OK handling wise.I think it is @4.5 inches.
Do not measure front the fenders lips, use the points on the rocker panel and suspension to floor as per the service manual.
1/4 may or may not make a diffence to your driveway scraping and 1/4 may not make an alignment difference...yet any time you adjust ride height a alignment check would be prudent.
Again just stay within specs and you'll be able to adjust alignment wise.
Unfortunately, the Service Manual procedure is to put the car up on an alignment rack and use a $250 tool to measure between two points on the suspension.
I can't find anything in the Service Manual about measuring from any part of the car, to the floor. Any measurements done that way would need to be corrected for tread depth on the tires.
I'm sure some racing teams or dealerships have established frame-to-floor specs they use, but I haven't seen them published; and they would need to corrected for our different tires.
If anyone has some good specs and can relate them to street usage, please post them!
