I havent cleaned the fluid yet... I should try that first you would think with the zo6 price tag it wouldnt be a part time job.
Cheap and easy to do. If for some reason you have to drop the driveline again for a swap, you should install a remote bleed kit. It's about $70 and bleeds the clutch fluid the correct way (pulls straight from the slave cylinder instead of the reservior).
fwiw - I've done the Ranger method 4 times in 6 months of ownership. It's easy and fast but I don't understand how it really makes a large impact.
I also just installed the remote bleed kit with new clutchware; seemed like the correct thing to do.
Good Luck with outcome - more power might cause more problem for your situation. I think camarochevyxxxx is esentially correct too. I'm looking forward to changing my fluid next available opportunity to see how my beast reacts.
