Brake fluid C6??
Old Dec 29, 2011 | 02:54 PM
itorfeo's Avatar
itorfeo
Default Brake fluid C6??
DOT4 may be placed instead DOT3 brake fluid ??
Thanke
Merry Christmas
Old Dec 29, 2011 | 08:12 PM
BEZ06's Avatar
BEZ06
Most all DOT 4 fluids are compatible with DOT 3, DOT 4 Plus (also called Super DOT 4), and DOT 5.1. They are pretty much all glycol ester compounds.
Take a look at this website and you'll see there is only about one of the listed fluids that isn't compatible with DOT 3:
http://www.seinesystems.com/BrakeFluids.htm
In the info on that site a couple of the fluids have an *, indicating they shouldn't be used in brake/clutch systems with magnesium, but our Vette system doesn't have any magnesium lines or caliper parts in contact with the fluid.
Don't ever use DOT 5!!!
DOT 5 is silicone based, not compatible with the other glycol ester fluids, and is not good in modern ABS brake systems.
Bob
Old Dec 29, 2011 | 09:55 PM
QwikC's Avatar
QwikC
ATE Super Blue Brake Fluid Dot 4, go between the blue and amber during bleeds.
Old Dec 29, 2011 | 10:34 PM
C7&7's Avatar
C7&7
Thanke
Merry Christmas
I used DOT4 in mine. Works just fine.
Old Dec 29, 2011 | 10:49 PM
Nightstalker Medic's Avatar
Nightstalker Medic
Old Dec 29, 2011 | 11:40 PM
taken19's Avatar
taken19
Track Junky
ATE is a good fluid for the price. Motul 600 is just a bit better but twice the price.
Old Dec 30, 2011 | 04:09 PM
itorfeo's Avatar
itorfeo
Thank you very much and happy 2012
To Brake fluid C6??
