battery terminals
Old Jan 1, 2012 | 02:36 PM
white top's Avatar
white top
Default battery terminals
I read that some have problems reattaching stock battery terminals after removal...can't get them tight enough.Any secret to this???
Old Jan 1, 2012 | 05:30 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Tech at the local dealer says he sometimes has to peen in the thin edges of the main piece that fits around the battery post.
One of mine broke. We covered everything in/around the engine compartment with sheets to catch the flying particles, then used a cutting wheel to carefully slice the crimp on the factory connection. That allowed us to remove the factory connector without losing any length on the cable, not sure if we needed to do it that way but longer is better.
We installed a common set of parts store clamp-on connectors, tightened onto the battery, and smeared it all with dielectric silicone grease. Working fine after 2 months.
Old Jan 1, 2012 | 05:42 PM
dennis50nj's Avatar
dennis50nj
I cut the end off leaving enough to drill and put a toyota replacement end from walmart still lightweight
Old Jan 2, 2012 | 02:42 PM
Gearhead Jim
St. Jude Donor '13
Do you have a pic of the toyota part?
Is it a crimp-on, or something different?
Old Jan 2, 2012 | 05:11 PM
dennis50nj's Avatar
dennis50nj
sorry i dont, it said toyota replacement end on the package it is chrome plated like a spring strap with nut and bolt to tighten, it attaches to a cable with an eye end with a wing nut and stud mounted on the end, thats why i took tin snips to my stock end cut it off leaving enough of the flat surface to drill for the stud.
Old Jan 2, 2012 | 11:25 PM
victorf's Avatar
victorf
I have no problem using the stock terminals. One thing you need to remember is don't macho out and go to town while tighten it!
Fineness is the key! The process I used is while tightening (I prefer to use 1/4" ratchet and 6" extension) gently with one hand, use fingers from the other hand to press down the opposite end near the cable to keep the terminal "balance", until tight. Once tight, don't go back and jiggle it hard. Once done, they will not come off as designed. Very little force and a few turn with the ratchet is needed.
On the other hand, if you are interested in changing out the OEM terminals, check out Tsunami TSBT-PT, well built terminals, easy to install and does not need any fineness for installation.
Give that a try, HTH!
Old Jan 3, 2012 | 10:53 AM
JRHAWK9's Avatar
JRHAWK9
Here is what I did. I also used a cut-off tool to remove the old terminals without losing any length. I also "tinned" the wire ends which makes tightening the set screws much easier and keeps the wire from "mushrooming" out when being tightened. I feel much more comfortable with these terminals compared to those cheap stock terminals.
Old Jan 3, 2012 | 10:55 AM
JRHAWK9's Avatar
JRHAWK9
I read this after I posted up my terminals, which happen to be the ones you mentioned above.
Old Jan 3, 2012 | 10:56 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Those Tsunami connectors were my choice too. Very solid connections for the wires.
Elmer
Old Jan 3, 2012 | 02:16 PM
Gearhead Jim
St. Jude Donor '13
Thanks!
To battery terminals
