05 corvette no dlc communication
Old Jan 2, 2012 | 04:06 PM
shayne2002's Avatar
shayne2002
2nd Gear
Default 05 corvette no dlc communication
I went to get my smog done, and found out that it failed. They said they could not link up to the car. I checked all fuses and battery is good. i tried to hook up my scan tool and found the same thing. it is unable to link with the car. any ideas
Old Jan 2, 2012 | 04:17 PM
nutz4c4's Avatar
nutz4c4
By your post title I think you would get a better answer in the C6 section....
Old Jan 2, 2012 | 06:18 PM
C7&7's Avatar
C7&7
This is the C6 section...????
OP. Try disconnection the battery for about 10 minutes then reconnect it. How old is the battery?
Old Jan 2, 2012 | 06:26 PM
djbrun's Avatar
djbrun
No power or a bad ground to the data plug. This is from my 08' manual but should be the same.
Pin 16 is battery voltage and 4 and 5 should be less than 1 ohm to ground.
DJ
To 05 corvette no dlc communication
