Dynapad VS Block-it Review
Maybe it’s just old age, but after living with borla stingers (aftermarket exhaust) for four years I wanted to revert to something a little more subtle. The noise in the interior cabin (mainly drone) was becoming unbearable. I’d find myself experiencing ringing in my ears similar to the aftermath of a heavy metal concert. However after going to my local dealer and hearing a stock corvette (no aftermarket exhaust), it reminded me as to why I got the exhaust in the first place, stock corvettes are too quiet.
After doing some research, I came across some materials /products that could deaden/tone down the drone, particularly the block-it pad by TKOperformance & Dynapad.
Although it seemed like a pricey fix (Dynapad: $120.00 & Block-it: $260 (shipped) , I jumped in and bought the two for testing .A lot of people seemed to have luck with either of them, so I thought by combining both I would get great results.
After installing block-it & Dynapad, I have to tell you I was a quite confused. To my very sensitive ears I could not hear a significant difference with either one installed or combined (one on top of the other). What the pads seemed to do was deaden the sound but by a very small margin.
Several people who regularly drive with me also stated that the pads made things slightly quieter; consensus was 5-10% quieter. Luckily, I had a DBA Sound Meter so I did some tests to quantify our opinions, I measured the DBA in C weighting to get the low frequency readings.
Conclusion: Does NOT reduce drone/noise sound significantly.
In terms of noise/drone the pads didn’t significantly reduce unwanted sound. Looking at the results below, average sound reduction was 2-5 decibels, which isn’t much of an improvement.
The block-it pad seemed to be more effective than Dyna pad but needed to be combined with Dyna pad to produce barely noticeable sound reduction.
Could be wrong, but if it were me, I might ask in this section for what they might do: http://forums.corvetteforum.com/audio-electronics-20/
Good luck with it.
* here's some stuff I found:
"What are the benefits of reducing vehicle noise?
Cutting road noise levels by 3 decibels is equivalent to halving the level of traffic. The decibel scale is logarithmic, so if a 3-decibel noise reduction means halving the traffic noise, a 10-decibel reduction would imply cutting the noise levels by as much as ten times. "
http://www.transportenvironment.org/...nd_out/.../664
Good luck with it.
http://forums.corvetteforum.com/c6-t...nd_out/.../664
However, human hearing perception is also logarithmic: the higher the sound in decibels, the larger the CHANGE has to be in order for you to detect it. So OP's perception can be realistic.
ETA: I cannot get your link to work, but since the dB scale is logarithmic we'd need to know what the initial measurement was (in your example) to determine how a 3dB change relates to the real world: is it a 3dB change from 10dB, or 100dB?
I had longtubes and stingers and neither myself nor my wife could tell a noticeable difference. I'm sorry you didn't find one of my posts complaining about it before you made the purchase. Luckily you will be able to re-sell it pretty easily though.
@ FloydSummerOf68 its ok Iam not bummed out about it. I had fun testing the different mats out. BTW both mats are made out of the same material.
Not that "better" is anywhere close to detectable in this case...
http://cascadeaudio.com/
Also understand in you are interested in making the car as quite as possible you will have a significant amount of weight added to the car.
I haven't heard of a shop around here doing anything like that. It couldn't have been cheap though, lol.
That, plus a blower, plus a re-upholstered interior in a GS and you'd have a world class car in every sense of the word.
