Alignment Specs Question
Old Jan 16, 2012 | 03:53 PM
Cherokee Nation's Avatar
Cherokee Nation
Default Alignment Specs Question
To the guys with a shop manual:I would like to know what the specs are on a BASE corvette,i know that the Z51,Z06 & the ZR1 are not the same.Thanks
Old Jan 16, 2012 | 04:09 PM
RicK T's Avatar
RicK T
Base, F55 and Z51 are the same:
I was going to say Dog walking as well. However, dog walking or suspension adjustment will not affect the HUD so I am assuming you are using the HUD as a reference to tell the car is moving the way you describe. It could be something as simple as the thrust angle needs to be a little closer to 0. Just because somebody says the alignment is in spec doesn't mean it is right. The specs are wide and if the alignment guy is lazy you will get a bad alignment.
If the thrust angle is off so the general thrust of the rear wheels is to the right the car will feel like it is turning left under acceleration and then turning back right with off throttle. It could be that just one of the rear tie rod needs adjusting or that the camber adjusting cams on one or both of the rear lower control arms has slipped. I had this happen after one alignment due to the tech not tightening them sufficiently. The =/- .2 degrees of thrust angle can be felt and visually noticed and should be set a lot closer to zero.
Old Jan 16, 2012 | 04:12 PM
saplumr's Avatar
saplumr
Alignment specs are all over the place. You get pretty close, a little close, kind of close and as close as you can.
Old Jan 16, 2012 | 04:55 PM
Cherokee Nation
Yes: i have read many threads on the specs they recommend,but i want to know what the GM specs are,the reason is i had a 07 base 2lt & it had 32000 miles on it when traded in,still had good tire wear.
Old Jan 16, 2012 | 05:35 PM
Cherokee Nation
I have read on this forum that the Z51 option is not the same as the Base vette ??
Old Jan 16, 2012 | 08:31 PM
BEZ06's Avatar
BEZ06
That chart in post# 2 is directly from the Corvette Service Manual.
I suspect it's a 2011 SM because I have 2006 and 2010 manuals, and the specs in that chart are very slightly different from my two model year manuals, and mine are both slightly different from each other (and the 2006 doesn't have the FE5 ZR1 specs of course).
Sorry, but the Z51 is a base Vette!! Like you say, Z51 is just an option on the base Vette.
The FE1/2/3 specs are all the same. The FE1 is the standard base Vette, the FE2 is a base with F55, and the FE3 is the base with Z51.
The FE4 is the Z06/GS, and the FE5 is the ZR1.
So.....Z51 has the same alignment specs as the other base Vettes, and factory alignment specs have changed slightly several times over the years.
Bob
Old Jan 16, 2012 | 08:41 PM
Cherokee Nation
Bob
Thanks BEZ06
Old Jan 16, 2012 | 08:44 PM
Cherokee Nation
My is a 08/Z51 option.
Old Jan 16, 2012 | 09:13 PM
Bill Dearborn's Avatar
Bill Dearborn
Chart is from the 08 Manual. Here is the same chart from the 07 Manual.
Bill
Old Jan 16, 2012 | 10:01 PM
BEZ06's Avatar
BEZ06
Bill
Hi Bill
Are you saying that chart in your post (reposted by Rick T in post# 2) is from an '08 manual?
That chart has the FE5 ZR1 specs, and the ZR1 didn't come out until '09!!
Below is the chart in my '06 manual:
You can see that those specs in my '06 manual are pretty much the same as those in your '07 manual, except for some slight differences in tolerances, and the caster is definitely different.
So.....specs vary slightly from year to year, and owners shouldn't be getting all worried about 5 hundredths of a degree!!!
Bob
Old Jan 16, 2012 | 11:44 PM
Bill Dearborn
Hi Bill
Bob
The 08 Manual does have the ZR1 alignment specs. I was surprised seeing that as well. However, can't ignore what is staring me in the face.
Bill
Old Jan 17, 2012 | 10:07 AM
haljensen's Avatar
haljensen
GM alignment specs are great IF you ignore the PLUS or MINUS factors and set the specs dead on.
Yes, it takes more time and a skilled mechanic to get to exact tolerances. That's why a GOOD PROFESSIONAL alignment takes an hour and costs $125.00. And it also explains how Bowling Green gets the alignment "within specs" in a couple of minutes and the the Dealer does an alignment free.
Accuracy costs time and $$.
Old Jan 17, 2012 | 10:09 AM
Cherokee Nation
Thanks guys, the camber looks to be the same on all the charts,that is what i was looking for.
Old Jan 18, 2013 | 10:50 AM
Steve Zaino's Avatar
Steve Zaino
Bob
Not sure if above bolded is correct. I have a 2011 GS and my build codes in the glove box says FE3.
Old Jan 18, 2013 | 05:33 PM
Bill Dearborn
I don't have any manual past 09. As you say the GS has the FE3 (Z51) suspension, however, that RPO has been around for a very long time and the suspension and settings change with the various models. The GS has different tread width and wider wheels than the base car so there could be some movement in the settings.
Bill
Old Jan 18, 2013 | 09:32 PM
BEZ06's Avatar
BEZ06
Yes, I think you're correct.
When I posted the earlier statement I was just thinking that the Z06 and GS were both wide bodies and have the same suspension, but that's not correct.
The GS has essentially the same suspension as the base Vette, not the Z06 (for instance, the way the rear upper A-arms are attached are the same as the base, which is different from the Z06 and ZR1.
The GS can be ordered with the Z51 suspension - that would be the FE3 RPO code.
Of course the GS can be ordered with the F55 suspension also.
I don't know what the Suspension ID is for the Z06 with MSRC.
So, I think my earlier statement is incorrect - thanks!!
Bob
Old Jan 19, 2013 | 02:40 PM
Steve Zaino
Along with the FE3 code, my glove box codes had the Z51 listed also. I have to believe that the Z51 is probably a standard feature of the GS model.
Does any one have the official GM alignment specs for the 2011 GS FE3 suspension?
To Alignment Specs Question
Old Jan 19, 2013 | 08:55 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
FE3 with XND or FE3 with XFA?
Old Jan 20, 2013 | 08:09 AM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
If you are looking for the best alignment specs for your car, go to www.pfadtracing.com click on support, technical information, and then corvette alignment. There you will find an alignment chart with specs tailored exactly to the use you intend for the car. The specs in the GM shop manuals have such wide parameters (+/-) that they are useless. The Pfadt specs have been used successfully by many on this forum.
Old Jan 21, 2013 | 10:23 AM
Steve Zaino
My codes have FE3 with XFA. also have YFJ, and Z16. These are all standard codes for the 2011 GS.
XFA= Tires, front P275/35ZR18 Eagle F1 Supercar, run flat
YFJ = Tires, rear P325/30ZR19 Eagle F1 Supercar, run flat
Z16 = Z16 Performance Package, performance-oriented package for the
Gymkhana/Autocross enthusiast; includes extra cooling, stiffer springs and
stabilizer bars, specific shock absorbers, larger brakes with 6 piston front
and 4 piston rear cross-drilled rotors, specific tires and Z16-specific 6-speed
manual when ordered with 6-speed manual transmission or (GU2)
performance axle ratio with 6-speed paddle shift automatic
