I am looking for some feed back from people using these alignment specs for their C6.
My question is what kind of tire wear are you getting? This is for my daily driver and I would like to get good tire wear.
Pfadt Corvette Alignment Recommendations
Performance Street
Front min max
Camber (deg) -0.7 -0.9
Caster (deg) 7.5 8.5
Total Toe -1/16" (0.17°) 0 (0°)
Rear
Camber (deg) -0.4 -0.6
Notes
These settings will provide good performance and good tire wear
There seems to be some disagreement among techs as to whether "-" toe is toe in or toe out. This shouldn't happen, but I've had different people with a lot of experience, give me different answers.
Someone else posted here that Pfadt means toe in when they use the -.
Sorry that I can only provide the question, not the answer.
How was the handling? (Yes, I want my cake and to eat it too!!)
I had an alignment done on my 2011 GS using those specs. I noticed that it didn't rotate as quickly, but only a smidge. If I get better wear (the insides were wearing at 750 miles) it'll be a win-win for me.
Here's what I have mine aligned to (the bottom specs, obviously) and I don't have any issues with tire wear. I also have my Firehawk aligned to very similar specs and no abnormal wear either. It made a BIG difference in handling in both cars. It's excessive toe coupled with camber that will wear the edges, as it scuffs the tire as you drive.
i have 1/16th of a tow IN up front. besides that, those are the exact specs i run as well. i had them setup during the corner balance..
Waiting to hear back from Pfadt on the toe. I will post the info when I receive it.
My OEM alignment had a bit of toe-in up front, toe-out in the rear. It made the car turn in faster but it was also darty on uneven surfaces, and it also seemed to have more throttle sensitivity during cornering, almost too much for my skill level.
I'm running zero toe now front and rear, and while it definitely feels more deliberate in turn-in and in mid-corner throttle adjustability, it's a less nervous fit until I become a better driver. It's now probably more suited to a higher speed road course than a tight autocross, but it's also way more relaxed over uneven freeway pavement, the tire wear is way better, and the gas mileage has gone up significantly.
hey guys! yes we have updated our alignment sheet to state that negative measurements indicated toe in, like negative camber is inwards as well (like normal), to keep it easy to remember. Take a look at the sheet below if any questions:
With negative toe the car will want to wander a bit, with positive it will want to stay straight on it's own.
In my opinion camber is way underdone on these cars...unless you never push the car in the corners
You can get away with 1 degree in the front easily without any uneven wear. I was actually still wearing the outsides of my RE11's more than the inside at a degree(w/o track use).
I haven't played with the caster any at this point though. Anyone tried this? I believe mine is around 9 right now; seems to steer really well with that setting. But I also changed camber at the same time so I'm not real sure what made the difference in steering feel(I was at 7.5 previously). But the increase in camber gave me tons more mid corner grip in the front.
Assuming you mean toe out when saying negative toe will cause wander I agree.
I have my Z06 set up with a slight amount of toe in (+) in the front and rear with -1.2 deg camber in the front and -1 in the rear. Almost every Z06 I have seen wears out the outside edges of the rear tires even though they have a lot of negative camber. When I reduced the rear toe in to almost nothing the tires started wearing better on my car and I have no wander even when running EMTs.
Bill
Sounds like a good setup...I'm gonna have to try and go to 1 degree in the rear like that.
Mid corner rear grip has been my biggest issue; but has actually seemed to improve a lot with the camber change to the front. I believe my corner speed has improved to the point where I'm not having to accelerate so much mid turn by keeping the roll speed up.
On freeway on ramps that go down hill, and tighten up at the end, I can hold way more speed with no fr. end push.
Bill- If your on the track a lot, try 2 degrees camber in the front
