C6Z Howling noise
Old Jan 24, 2012 | 10:13 PM
AtomicBob's Avatar
AtomicBob
Default C6Z Howling noise
I have searched everywhere trying to get an idea for what this noise is coming from my car. It sounds like wind howling and happens mainly when I am on the highway. Whether clutch is pressed in or not the sound remains. At time I can play with the gas and make it go away but it comes back out of nowhere. There's nothing I can really do to make it happen. It's extremely loud and annoying. It's probably coming from rear end or transmission.
Ive read some people seem to have similar issues but no one has identified the problem. Someone please help so I know what to replace without having to tear this car apart searching.
Old Jan 24, 2012 | 10:31 PM
RicK T's Avatar
RicK T
Might want to also ask in the Z06 Forum, in case it's something Z06 specific and for more eyes to see. Good luck.
Old Jan 24, 2012 | 11:14 PM
torquetube's Avatar
torquetube
Has your '07 Z06 had the roof recall service performed?
Early-production '07s were still being built with the defective polycarbonate roof. When the adhesive that holds it together starts to fail, you'll suddenly hear a wind roar when you exceed a certain speed.
Another possibility is the cowl trim at the base of the windscreen. However, most people with that issue strongly identify the noise as coming from the dashboard area, not from the rear end.
Old Jan 25, 2012 | 08:13 AM
1fastbob's Avatar
1fastbob
If the sound is changed by using the gas pedal it is probably drive-line related (drive shaft, transmission, rear end, wheel bearings, etc). It could also be the exhaust rubbing and vibrating somewhere especially if it has been modified.
I think the roof de-lamination does not apply to a Z06 as they had fixed roofs. (Please correct me if I am wrong).
Old Jan 25, 2012 | 11:01 AM
jedblanks's Avatar
jedblanks
Roof delamination does apply to Zs and I think the cutoff date was sometime in fall 2006 when 2007s were already mid production.
The OPs noise sounds like TT tranny or rear end. It could also be tires. Is it speed related? Does it change in other gears?
Old Jan 25, 2012 | 02:31 PM
cclive's Avatar
cclive
Yup, a friend's 2007 Z06 lost its roof on the highway...definitely an issue in spite of the fixed roof. I use the term "fixed" loosely!
Old Jan 25, 2012 | 03:13 PM
JoesC5's Avatar
JoesC5
Sounds like the ring gear & pinion, because of the noise changing depending on whether the car is under power or coasting.
Old Jan 25, 2012 | 03:21 PM
AtomicBob's Avatar
AtomicBob
its not the roof. Definately drive-line related.
Old Jan 29, 2012 | 09:20 PM
AtomicBob's Avatar
AtomicBob
anyone else?
Old Jan 29, 2012 | 10:18 PM
4SUMERZ's Avatar
4SUMERZ
Wheel bearings will make a howling noise, but will quiet down if turning one way or another if it's the front wheel bearings. The back ones will howl pretty much all the time when their bad.
I've replaced many on my other GM vehicles in the past.
Old Mar 22, 2012 | 08:48 AM
AtomicBob's Avatar
AtomicBob
ive noticed the noise mainly happens when i am in 6th gear. Once in a while it will do it in 5th. Never heard it in any other gears. So the noise seems to appear depending on load?
Old Mar 22, 2012 | 01:38 PM
dovervold's Avatar
dovervold
OP, I have a 2007 Z with 14k miles, and a very similar noise. It is intermintent, and only happens when drive train is lightly loaded, just cruisin along around 2,000 RPM's. I have determined it to be the ring and pinion that likes to howl at just the right time with a very light load on the drive train. I am not even too bothered by it, just add a little gas and it goes away Honestly, mine only does it sporadicly so not going to worry about. If you find something more definitive, please pass it along.
I wonder if changing the differential fluid would take care of the problem, might be worth a try,
Old Mar 22, 2012 | 01:42 PM
AtomicBob's Avatar
AtomicBob
I believe it to be the ring and pinion as well. I think i will be changing the rear diff fluid tonight although i dont think its going to do anything.
Old Mar 22, 2012 | 02:53 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Whiny differential. Usually goes away in 4th or 5th gear as soon as you let the gas pedal go but comes back right after.
Old Mar 23, 2012 | 04:57 AM
Tone's Avatar
Tone
I know in my old C3 the ring and pinion pattern was adjustable using shims and could affect rear-end noise, so maybe the C6 is similar.
Old Mar 31, 2012 | 03:46 PM
AtomicBob's Avatar
AtomicBob
Spoke to RPM and the noise described does not sound like a bad ring and pinion. They seem to believe it is the pilot bearing.
I am finishing up my ZR1 clutch install on my car with new pilot bearing. I will keep you guys posted.
Old Apr 4, 2012 | 10:20 PM
AtomicBob's Avatar
AtomicBob
So it's not the pilot bearing >:O may try a new ring in pinion in the future. On the bright side the zr1 clutch is BADASS!
To C6Z Howling noise
Old Apr 4, 2012 | 10:39 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Old Apr 5, 2012 | 12:10 AM
C6topless's Avatar
C6topless
Have you swapped out the fluid it the in the differential and did the figure 8 trick?
Old Apr 5, 2012 | 07:59 AM
AtomicBob's Avatar
AtomicBob
Sure did and she still screams at me on the highway.
