LS1 MAF meter on LS2
Old Jan 25, 2012 | 07:46 AM
Smacyko's Avatar
Smacyko
Default LS1 MAF meter on LS2
My question is, can an LS1 mass air flow meter work on a LS2 car?
I just bought a CAI for a forum member and the MAF meter shows up to be for the LS1/LS7 engine.
Currently it is installed on my LS2 but I have only put 30 miles on this setup. No problems yet, but I do think it lags more when I punch it.
Old Jan 25, 2012 | 10:09 AM
Smacyko's Avatar
Smacyko
The lag could be from the computer still recalibrating but I'm not sure yet
Old Jan 25, 2012 | 12:34 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Did you mean to say LS1/LS6? They used the same same sensor from 01-07. So the LS2 sensor was the same part number as the LS1/LS6. Now the LS3/LS7 is a different meter all together and it does not hook up the same way your old one does, it will not plug in without and adapter and your car would not run very well if you were to make physically go in place without some calibration changes. You should not see a lag introduced from the meter unless something is wrong with it. The lag may be from the air box iteself, hard to say without know what all has been done and what type of CAI it is.
Old Jan 25, 2012 | 01:31 PM
Smacyko's Avatar
Smacyko
Ok. The MAF meter I took off had a different serial number than the one I received. They are both the same brand just different numbers. The CAI is haltech killer bee.
Should I have or need to disconnect the battery from changing the sensors?
Old Jan 26, 2012 | 09:13 AM
Zip Corvettes
No, you don't need to disconnect the battery. There is no power on the meter when the key is off. What is the part number on the new meter?
Old Jan 26, 2012 | 09:22 AM
Smacyko's Avatar
Smacyko
It's a dolphi 25168491
Smacyko's Avatar
Smacyko
Which is not the same number on the one I took off
Old Jan 26, 2012 | 10:48 AM
Zip Corvettes
What did you take off, and what year is your car?
Old Jan 26, 2012 | 10:55 AM
Zip Corvettes
looks like part number 25168491 was superceded to 25318411 and then again in 2007 to 15904068. These are all functionally the same sensor, don't know what changed to make GM change a part number but they are all used on the same applications. If you go and purchase one from GM you will receive the latest part number which is the 68.
Old Jan 26, 2012 | 11:03 AM
Smacyko's Avatar
Smacyko
Mines an 07. Don't have the part number right now.
Old Jan 26, 2012 | 11:05 AM
Smacyko's Avatar
Smacyko
But that is good they are the same sensor. I was worried cause of the different model number
Old Jan 26, 2012 | 11:07 AM
Smacyko's Avatar
Smacyko
And when I referenced the number everything was ls1/ls6
To LS1 MAF meter on LS2
