Fender Stripes INSTALL?
Old Jan 31, 2012 | 06:44 AM
Speedway1's Avatar
Speedway1
Default Fender Stripes INSTALL?
I ordered GM fender stripes. Has anyone put these on before? They look like they center the front wheel and are a couple inches away from the rear of the headlight. Can some one tell me the exact distance from the headlight.
Old Jan 31, 2012 | 06:51 AM
sguido2's Avatar
sguido2
I understand the GM kit comes with a template, I also plan on buying a set.
Old Jan 31, 2012 | 03:27 PM
Speedway1's Avatar
Speedway1
Thanks,good to know that. Im thinking of trying it myself. However they are big bucks would hate to mess up.lol Wish there was a video or something to show where to begin.
Old Jan 31, 2012 | 05:02 PM
Speedforhire's Avatar
Speedforhire
Tune in tonight.......I'll upload a few pics for your viewing pleasure!
Old Jan 31, 2012 | 06:05 PM
sguido2's Avatar
sguido2
It's a decal rather then a sticker, not to tough to do yourself, keep wet with soapy water until satisfied with location.
Old Jan 31, 2012 | 06:26 PM
KKJ's Avatar
KKJ
I put them on my car myself. I was a little nervous because of the price of them. They turned out great. They come pre-stuck to a template that wraps around the curve of the headlight so you know exactly where to place them. A little tip I would have would be to have a hair dryer close by so you can give it a little heat to help them wrap around the curves of the fenders a little better. I did my passenger side first without any heat. It worked, but then I tried it on my driver's side with a little heat, and it was much easier.
Old Jan 31, 2012 | 07:22 PM
Speedforhire
These are the GM oem stripes that came with my car. They are Light Silver with Cyber Gray borders. I haven't mounted them yet because they do not flow well with the CRM. A reverse color stripe would be better on my car. They come in a heavy cardboard and are flat. If you buy from a dealer, they should come to you like these. If you buy from a 3rd party, they will probably come to you in a poster roll.
They come with detailed instructions & alcohol wipes.
Instruction page.
They are laid out in template format for easy mounting. Align the forward edge at the headlight curve then the bottom edge slightly above the fender flare. It should not be placed at the edge, on top of the flare curve as that will cause it to peel prematurely. The template has about 3/16th of spacer on the bottom edge and that should be on top of the curve.
Do a few trial fits before attempting to mount them. Do you see the two cutouts below each of the stripes? Those are for you to do correct alignment on the curve, to better facilitate placement. DO NOT MOUNT THEM DIRECTLY ON TOP OF THE CURVE: THEY WILL PEEL OFF PREMATURELY!
Follow the instructions closely. The key is to keep the backing wet so if you aren't happy with your outcome (before the squeegee process) you can remove them and start over..........don't use too much soap in your mix! Using a hairdryer, after squeegee, will help alot with the lying flat and curing process.
Old Jan 31, 2012 | 07:29 PM
sguido2's Avatar
sguido2
great pics and info. thanks
Old Jan 31, 2012 | 08:18 PM
Speedway1's Avatar
Speedway1
Thanks for the great info.Just what I was looking for!!! I ordered mine from the GMpartshouse.com. They better come with everything for 400.00.
Old Jan 31, 2012 | 08:25 PM
Speedforhire
Color?
Old Jan 31, 2012 | 08:27 PM
sguido2's Avatar
sguido2
I'm waiting for the next discount price sale, I think it's the tax day sale....
Old Feb 2, 2012 | 01:12 PM
MikeSVT04's Avatar
MikeSVT04
vettestripes.com........you are paying $300 more for the GM ones bc of the little *** in the corner. They can make any color combo you want.
figured I would let you know, if you didn't hear about them.
Old Feb 2, 2012 | 02:21 PM
Tikiman12's Avatar
Tikiman12
lol yeah, Chevy knows how to make a buck of the corvette group. Its a vinyl sticker with a proprietary emblem on it. Take the emblem off BAM savings of $275 or more.
Old Jul 27, 2012 | 09:48 PM
talbertisp's Avatar
talbertisp
4th Gear
Default Fender strip installation
The template makes the installation very easy. Mine look great. These are the genuine GM Ron Fellows stripes.
Old Jan 21, 2013 | 12:41 PM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Thanks alot. Great info. I'm going to install in the spring.
To Fender Stripes INSTALL?
