Supplemental system that works independently of engine function and modifies the ambient intake supply. If an engine tuned for it is stripped of it, it either goes boom, or like a popped charge pipe, loses all the induced power.
Not a C6 but a C6 block. My LS3/416 laid down 573/530rw on a DJ SAE three or four years ago. Still needed cut out's, EWP, and FAST 102/102. Didn't exist back then. Car ran 10.2 @ 137 with stock gearing at 555/505rw with a 1.55 60ft.
Lingenfelter: Cold Air Intake, GT11 cam 215/231 .631/.644 118.0 C5R timing chain. LPE Large valve ported heads. 2.055" / 1.57". Yella roller rockers. Manta pushrods. Ported throttlebody and Fast 92mm intake. TB Spacer. 47 lbs injectors. Kooks 1 3/4 headers with High Flow converters. Electric exhaust cutouts. Corsa Sport Mufflers. DTE HD differential with 3:90 gears. Bilstein Sport shocks. Dewitt’s radiator with large oil cooler, MGW short throw shifter
mine is about to take that crown, view my latest thread
I did, and I don't see much. There's a lot of high comp strokers in C6's. And you can't make claims about taking a crown if you aren't willing to provide some sort of evidence as to why your LS3 based stroker with LS3 heads and an off-the-shelf X3 is going to out-muscle the 440-500ci+ custom-block based C6's out there.
oh im sorry, i thought you were talking about a C6 with a LS3, not just any random motor dropped in. My brothers 482 ci warhawk put down almost 800 hp NA. but i just mis understood the post then.
That is the only way I do it. It is nice to know what you really have. Wish I still had the car. Technology has come so far in the last four years that I am sure that motor would have been well into the 600rw range now. You have a great combo if you are putting down those numbers through an auto with a 230's cam.
