Two questions, beyond the obvious better traction, is there benefit to changing from the factory run flats to a soft compound tire? I believe so based on what I have seen in other posts, but why?
Second, I have a spare set of wheels that I would use for race tires, will the swap send an error code when the PCM does not detect the air pressure sensors in the new rims?
