FAST102 Intake......Best Power Mod for a LS2????
Old Feb 10, 2012 | 02:07 PM
Shifter6's Avatar
Shifter6
Default FAST102 Intake......Best Power Mod for a LS2????
The more I read about the FAST102, the more it seems it’s the most effective power mod for a LS2. It seems like a great addition for both bolt on cars and max effort setups. Some reasons why it seems like the best:
Noticeable increase in peak power and tq.
Noticeable increase in midrange power/tq and improved throttle response.
Very good cost per hp ratio.
Simple install with no lift or jacks needed.
Essentially NO DOWN SIDES! No drivability issues or compromises. It just replaces the stock manifold and provides so much more.
Can you think of another mod that does this much??? Why does it seem like headers are a more common mod than a FAST intake. The FAST is cheaper, easier to install and makes similar power gains.
I mean what bad can be said about a FAST102. And no I don't work for FAST, hell I don't even own one. I just want to know why this isn't the first mod that any LS2 owner, looking for more power, does?
Old Feb 10, 2012 | 02:09 PM
superscout03's Avatar
superscout03
cam = best mod
Old Feb 10, 2012 | 02:18 PM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
While a cam swap is my favorite mod too, for "best" you have to take into account the user. Most DIY'ers can install a manifold with no experience. A cam, not so much. As far as ease of installation and overall cost, well... cam+install+tune, typically around $2500 on a C6. Manifold + home-install + tune = maybe $1500. With no other mods made, will the cam pick up a commensurate amount more power for what you paid, and will it be as one-sidedly (made that up) positive as the manifold?
With all that said, headers + home-install + tune = $2000 (best mod).
Old Feb 10, 2012 | 02:19 PM
Devilish34's Avatar
Devilish34
It's a nice supporting mod to a bolt on car but not the first I would do. If I remember correctly my car picked up 20/27 with a ported 102(tuned) over CAI, 1 7/8 LTH(tuned)..
And a 102 will need a tune so factor that into your $$ to HP/TQ number
Old Feb 10, 2012 | 02:38 PM
superscout03
ok then how about this. a simple NOS 100 shot system + tune = about 1,500 bucks. and a simle user can install all of that.
Old Feb 10, 2012 | 02:41 PM
Shifter6's Avatar
Shifter6
OK a cam definetly can add more power for less, but the install is far more complicated plus you have some sort of compromise with drivability. Show me a cammed car with a significant power increase, where you could never tell it was a cammed car.
LTs are a great power mod, but again the install is more complicated and don't they cost more. It seems like typical power gains are around what the FAST picks up.
Old Feb 10, 2012 | 03:54 PM
Devilish34's Avatar
Devilish34
I doubt you will see the gains you are talking about without supporting mods.
Old Feb 10, 2012 | 03:58 PM
ctusser's Avatar
ctusser
I understand your reasoning, but you may be off track. You seem to expect results obtained by more modified cars. Whereas just a fast manifold on a stock car might only get an increase of ten hp or maybee less. I've never seen a fast result on an otherwise stock car before.
Old Feb 10, 2012 | 09:35 PM
Shifter6's Avatar
Shifter6
Good point, but if nobody has tried it, how do we know it doesn't perform to that level?
Lets look at basic no-cam bolt on cars. If you have a MN6 LS2 you are dynoing about 345rwhp bone stock right? I have seen plenty of LS2 cars with bolt on mods (no cam/heads) crack into 400rwhp, do you agree?
So if you agree to the above two points how do most people get the extra 55rwhp? The most popular mod is exhaust. So what are 1 3/4 LTs, xpipe and axle back worth...25rwhp??? Maybe with a tune. OK whats next, the LS2 intake system is pretty crappy, a good CAI or AI should get you 5rwhp, right? Stock MAF and TB are good at this power level, so what else is there? Maybe a pulley but I can't imagine even 5rwhp from that.
Even so that leaves 20rwhp left, and thats where the FAST102 comes in.
I am saying take a bone stock car and add a fast 102 and tune and you will have at least 95% of the power gains of LTs and a tune. Because of the cheaper cost and easier install, the FAST is a better mod.
Old Feb 10, 2012 | 09:53 PM
C7&7's Avatar
C7&7
The FAST 102 is an outstanding mod on a LS2, but I have to agree that I have never seen one done without supporting mods such as a cam or heads, etc. I picked up 20/20 with a little baby G5X1 cam and headers. Made 445/425 with that setup.
It's a great mod. However best $ for HP is headers & cam.
Old Feb 10, 2012 | 10:24 PM
ctusser's Avatar
ctusser
I think typical cai and header car results are in the mid 380whp range. And the cai is worth more like 10hp.
I Hope you do this though, and post up results.
Dragracer_Art's Avatar
Dragracer_Art
I don't think there is a single "mod" that will trump all others. It's more of a cumulative effect by matching a combination of proven parts that work well together.
In an effort to reduce the number of "tunes" my car will need... I'm taking a different approach. I'm replacing stuff that will benefit the package, but won't adversely affect driveability without a tune.
A cam swap will require an immediate tune. Intake and headers ? not so much.
I plan to put headers on my car first... then a Fast 102. I'll probably put nitrous on it next and then take it to the track to baseline it on external mods only. After that... it will probably get a cam and converter, possibly gears too.
Old Feb 11, 2012 | 09:09 AM
Shifter6's Avatar
Shifter6
I am seriously considering it. Put my money where my mouth is.
I already have a basic AI (Airaid) I think would be good for at least 5rwhp. I guess the most common route people go is CAI, LTs and tune, right? Mid 380rwhp seems kind of high...but maybe.
So what happens if I go airaid, FAST102 and tune. I am guessing at least 370rwhp. Very similar to gains with headers for less money and much easier install.
Old Feb 11, 2012 | 09:13 AM
C7&7's Avatar
C7&7
I think you will see about the same gains as long tubes. A tune will be nessasary though with CIA and the fast. I've seen ls2s with long tubes, fast 102, CIA, and 160 stat be around 400
Old Feb 11, 2012 | 02:13 PM
383's Avatar
383
^SPOT ON^
Kooks 1 7/8", catted X ,stock mufflers, Ported FAST, VR cai
http://www.youtube.com/watch?v=zYrw9...HR1Niu9km1LLTR
Old Feb 11, 2012 | 02:42 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I think if you asked a lot of people with ls2 mod experience you would find the fast is not the lowest hanging fruit and doesn't have nearly as big effect if you have stock exhaust and cam.
I think the fruit hangs from the tree in this order, and the mods are complementary as you go up the tree.
CAI
Tune
Headers
Cam
Fast
Ported/Aftermarket heads
Old Feb 11, 2012 | 07:32 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
A ported FAST 102 and set of ARH Headers tuned on my 06 gained 55rwhp and 30 lbft torque.
To FAST102 Intake......Best Power Mod for a LS2????
Old Feb 11, 2012 | 08:11 PM
LS1LT1's Avatar
LS1LT1
As long as one doesn't get way too elaborate with the system's complexity, nitrous is clearly the path to the single highest amount of power for the least amount of money.
But it is only temporary so to speak as well...FAST intakes, cams, headers etc all give power full time all of the time.
Old Feb 11, 2012 | 08:44 PM
Shifter6's Avatar
Shifter6
CAI
Tune
Headers
Cam
Fast
I agree that is what most people would say. You have laid out the most common mod path that I have seen on this board. However I think the LS2 intake manifold is overlooked as the lowest hanging fruit. Nobody that I know of has a CAI, FAST102 and a tune. Or put another way, no one has a fast102 without headers. But of the cars that have both, (no cam) gains of over 50rwhp seem typical. If you break down those numbers power gains from the fast102 must be very close to what LTs add.
So the bottom line is what is the weaker link on a stock LS2? The factory intake manifold or exhaust manifolds? Probobly the exhaust manifolds, but not by much if at all. I guess we will never know for sure until someone installs a FAST102 BEFORE LTs.
I still say the FAST102 should add power similar to LTs, even if it is only95% of LTs, once price and install are considered the FAST is a superior mod.
Old Feb 11, 2012 | 09:40 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
The exhaust manifolds are the bigger restriction. That's why people take care of them first. The manifold isn't a restriction with stock manifolds and even then not much with stock cam.
