fuel pump hot wire kit
Old Feb 10, 2012 | 08:54 PM
BT03mach-1's Avatar
BT03mach-1
Default fuel pump hot wire kit
I got a fuel pump hot wire kit to install in my 05 c6. i can't find the connector you plug into at the fuel pump. i looked right at the fuel pump harness and the connector thats mounted to the frame is the only one i found and it a 6 pin. the one with the kit is a 4 pin. a connector on top of the fuel pump is a 3 pin.
am i looking in the wrong spot?
Old Feb 10, 2012 | 08:59 PM
turbo2001's Avatar
turbo2001
Default hot wire kit
are you referring to the the racetronics kit for c5 c6, if so i started to install mine and found you have to drop the drivers side gas tank, so i'm waiting till the next time i have to pull the trans and diff
Old Feb 10, 2012 | 09:06 PM
BT03mach-1's Avatar
BT03mach-1
the driver side? the pump is on the passenger side?
yeah its the same i think. the one i got is from casper electronics.
all the instructions say is find the fuel pump bulkhead at the gas tank and plug in the kit between the connnector...
Old Feb 10, 2012 | 09:39 PM
turbo2001's Avatar
turbo2001
Default harness
does your harness power up from the alternator?
Old Feb 10, 2012 | 09:52 PM
brodyscorvette's Avatar
brodyscorvette
The pump is located on the driver's side...
Old Feb 10, 2012 | 10:05 PM
BT03mach-1's Avatar
BT03mach-1
well thats the problem then i was on the wrong side. What is the pump on the passenger? just pumps fuel from that tank to the other?
i went by aeromotives tank removal instructions and it said start on the passenger side and remove inner wheel well plastic and the unplug pump harness so i thought that was it LOL
i guess thats what i get for not reading the instructions all the way.
Thanks!
To fuel pump hot wire kit
