[IMG][/IMG][IMG][/IMG]Had great weather today and I had fresh set of drag radials, adjusted my tune for the new Fast 102. Tire pressure was at 22 psi and car ran 11.194@122.53 with a 1.574 sixty foot, Next pass it ran 11.267@120.82 with a 1.567 sixty 3rd pass 11.265@120.78 with 1.563 sixty And after a 1 hour cool down it ran 11.235@122.34 with a 1.599 sixty. My previous best was 11.53 @ 121 with a 1.71 sixty. Weather at State Capitol Raceway in Baton Rouge Temp 45 deg, DA -1700, BP 30.53, Hum 45. Car ran perfect all day and never had any issues with hitting rev limiter like my last time out. Also Randy from Ragin Racin was there and he ran 10.20s@154 mph with his Supercharged Z06. [IMG][/IMG]
Good solid passes with great times. Congrats on the PB.
Originally Posted by LS1LT1
Originally Posted by Joe_G
Great 60 foots for a 3200 stall, most guys need a 3600+ to get those times it seems. Also quite fast for bolt ons only!
Thanks guys, I did alot of research on this forum and got all the best info and parts that have been proven to work. The FTI 3200 converter is really great. I though about a 3600 stall but my original plans were to run 11.50s and I didnt think I need a 3600 to get there, I don't think I will do anything else but front skinnies. So I might not get a 10 second pass but I never intended to go faster than 11.50s. I am very happy with the results, but I think anybody can do this with the right parts.
Congrats on your new best.
It was a good run, and I agree completely. Low 11s should definitely be the norm for a bolton LS2 if you have halfway decent air.
The stall speed has much less to do with it than the STR of the converter. The 400 RPM difference doesn't matter much.
A 3200 converter can vary greatly....hence his FTI cutting 1.5s compared to me and Larry's Yank cutting mid 1.6s
Justasheet went from consistent mid 1.6's to high 1.5's by changing from 18" drag radials to short M/T 275/40/17 DR's. We spent time yesterday tweaking his shift points and getting him a new record slip.
Well Larry and I already run that setup.
I don't believe anyone has gone better than mid 1.6s on a 3200 Yank converter in a bolton car. The STR is simply too low on it and it is VERY tight.
Other companies put a higher STR in a 3200 converter whereas yank doesn't start until the 3600 unit, which is why there is such a huge discrepancy between the times people produce with the Yank 3200 and the Yank 3600 (between .3 and .4 difference in ET for the two)
I'm hoping that my FTI 3800 2.5 STR gets me into the 1.5's with ease. I'm looking forward to comparing the results to a friends SS3600 Yank. that has even more HP/TQ.
Terry you will be in the 10s soon, guess the fast 102 is great
The Fast 102 is worth every penny on a LS2. Not sure if I will ever see 10s but if the skinnies help me to get there that would be great. I wish I had them this weekend because we had -1700 DA here Sunday. I hope we get some good air soon and I will see what it can do. Not to many bolt on LS2s in the tens with stock 2.56 gears.
Dennis thanks for the vote of confidence, I think the LS2 motors are just as strong as the LS3 with a fast intake, If you look at the bolt on list there are a few LS2 and LS3 running very close in times with the same mods.
My best 60' with the 3200 was 1.70 and the 3600 was 1.55. Because there were other changes that happened at the same time as the converter swap, I can't attribute any particular mod to an ET difference.
Larry (8850) ran a 10.94 with a Yank 3200, but even as strong as his car runs, I highly doubt simply swapping to a 3600 would put him in the 10.54-10.64 range. I could be wrong, but I'd suspect more toward a 10.75-10.85.
There are a few A6 cars in the 10's while still running a 2.56 or 2.73 gear and teetheriot may get there too.
I suspect that the -1650ish difference between the 11.6 and 11.2 was the main factor... if we say that you were .2-.3 faster from better air that only leaves .1-.2 from the Fast 102 which seems to be on par with the few results we've seen lately.
If my car gains more than .2 tomorrow with the 102 after DA corrections then you can call me out! LOL
