New thread...Wont start after HUD install
Old Feb 20, 2012 | 05:36 PM
stargate's Avatar
stargate
Default New thread...Wont start after HUD install
I went back in and disconnect the HUD that I installed and all is good. Im thinking that I might have hooked a wire up wrong but they all look good. I did not have the correct switch in that kit that Patrick sent so I just left the car without a switch until he sends the correct one. Will the car not start if there is no switch for the HUD in place. Ill double check the wiring first. Any hints?
Old Feb 20, 2012 | 05:47 PM
C7&7's Avatar
C7&7
I would say yes, an open circuit on a switch could cause a problem. Possibly voltage isn't getting to the ignition switch because of it or something. The HUD has to be wired into ignition in some fashion or it wouldn't come on when the car started. Is it just a pair of wires that go to the switch? What switch is it? Maybe just tie them together and bypass the switch?
Old Feb 20, 2012 | 05:55 PM
stargate's Avatar
stargate
the HUD kit was packed with the wrong switch. Everything works as advertised with the HUD connector disconnected. Was very careful with the wiring checked all connections with an ohm meter. Either a wire is wrong (my car could be possibly wired different?) Colors matched custom cable labels. Could have a bad HUD unit or switch needs to be present.
only really 3 options that I can think of...new switch will be here This week.
Old Feb 20, 2012 | 05:59 PM
C7&7's Avatar
C7&7
I would wait on the switch.
Old Feb 20, 2012 | 06:16 PM
stargate's Avatar
stargate
Yep...thats what Im gonna do...I'll recheck the wiring at that time
Old Feb 20, 2012 | 07:08 PM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
when you modified circuitry on LED board do you think you could have backfed something and burned up the projector?
Old Feb 20, 2012 | 08:01 PM
stargate's Avatar
stargate
possibly....that is still one of my could be issues...if so Ill buy a new unit. I see no reason that I have these issues and they go away when I disconnect the HUD other than HUD, or wiring...pretty sure wiring is correct but you never know. Ill check it all when I get the correct switch from Patrick. Ill also check the cable that came supplied with the kit to make sure it is wired correctly/label correctly. You never know!
Old Feb 20, 2012 | 08:43 PM
Former Vendor
where are you located? I can test everything you have and I have a switch to see if thats the problem.
Old Feb 20, 2012 | 08:53 PM
stargate's Avatar
stargate
ga...but headed to Vegas Friday for 6 weeks....
Old Feb 20, 2012 | 08:56 PM
Former Vendor
Where in Georgia, maybe I can send a friend your way to troubleshoot it.
Old Feb 20, 2012 | 09:00 PM
stargate's Avatar
stargate
Thanks for the offer but I'm really pressed for time between now and Friday morning. I think the car is going to have to sit until April. I'm near Macon. Worse comes to Worse I'll buy another kit and reattempt later
Old Feb 20, 2012 | 09:02 PM
Former Vendor
Thats not too far off, I can see if my buddy has some time and can run over and see what the problem is.
Old Feb 20, 2012 | 09:23 PM
stargate's Avatar
stargate
Thanks for the phone call Andrew....It's guys like you that make this forum!
Old Feb 20, 2012 | 09:28 PM
Former Vendor
Old Feb 21, 2012 | 12:42 AM
Z16chevelleguy's Avatar
Z16chevelleguy
When i installed my Hud the car would not do anything. It acted like a dead battery. I tore it apart and checked everything out. What i found is the plug that goes to the projector was not plugged in correctly. As soon as put it back together it started right up.
Old Feb 21, 2012 | 05:19 AM
stargate's Avatar
stargate
That is exactly what mine is doing....don't see how you can plug the connector in wrong though.
Old Feb 21, 2012 | 06:25 AM
Former Vendor
Has to be plugged in all the way and might be an opened end without switch
Old Feb 21, 2012 | 09:00 AM
stargate's Avatar
stargate
It was snapped in place..my hands took a beating trying to unplug it. Who ever said that you would have some cuts sure was right. I don't see how you guys do that without beating the crap out of your hands.
Thanks again Andrew!
Old Feb 24, 2012 | 04:28 PM
Z16chevelleguy
Well it wouldnt start, unplugged it and car fired right up- plugged it back in and it fired right up- it either wasn't plugged in completely (correctly) or it was a fluke
I then tried to unplug it and had a hell of a time. So I am guessing it wasn't completely plugged in the first time.
To New thread...Wont start after HUD install
