Not really the most technical question, but are there any down sides to removing the engine covers on an LS3 Corvette?
I came from an LS2 GTO were it was a rule of thumb to yank the engine covers, unless you wanted to watch your Goat burn, but most of the Vettes I see have the engine covers in place.
I guess I just prefer looking at the motor when I pop the hood, I actually think the LS motors look pretty dang good naked.
I removed the covers and hood insulator quite some time ago. I haven't experienced any issues on the street, track, or in the rain. I used to keep them on for hood-popping car shows but since I don't bother with that anymore (still go to shows, just don't pop the hood) I keep everything off to help with heat dissipation. Personally most modern engines look like sh*t with all the wires, hoses, etc. Especially the coil pack set up of the LS engines. JMO.
Too funny, first thing I did when I had a GTO but ive been reluctant on the Vette...May yank them yet...
I don't understand why people don't want to see the coil packs. A motor with eight individual electronically-controlled coils - that's trick stuff. Not to mention the narrow valve covers and plainly-visible spark plugs that are right there, underscoring just how compact a 2V pushrod motor is.
With the plastic covers, we are presented instead with a caricature of a conventional, top-heavy DOHC engine. Mine came off the day I got the car home.
And in addition to looking silly, they get in the way of maintenance.
To each his own. I just don't care for the cluttered look. I'm not saying the technology isn't "trick" but the way it's displayed isn't anything special to me. The valve covers are dull grey and boring looking. Those that have done aftermarket coil relocation kits, valve covers, colored wires/hoses, and other various underhood bling are the obvious exceptions. Stock just looks plain and cluttered to me but I don't like spenidng money on underhood cosmetics since the hood is closed 99% of the time.
the first things i did were remove the engine covers, the inner vanity hood cover insulation thing, and the inner fender vent grills/covers
all just hold in more heat
I was debating removing the inner fender/side vent pieces as well. I was in there a few weeks ago and it doesn't look like it's a straight path to the engine bay. I'm sure every little bit can help, even if it's unmeasurable. Was it that involved in removing them?
