catch can hose routing
Old Feb 25, 2012 | 10:16 PM
Mattraffai's Avatar
Mattraffai
Default catch can hose routing
ok so i bought a ebay catch can that had 2 original outlets coming out of side but my friend said it would not work unless we added a 3 outlet, 1 one top so i went with he said and he drilled out a hole on top and added a 3rd vacuum hose connection. I"m wondering if he routed it right? He has the driver side valve cover vacuum connection wrapped around back of intake going into a t connection right at the bottom of the intake vacuum connection. Then he has the passenger side valve cover vacuum connection going straight to the other side of the catch can. the final connection the 3rd is routed from the top of intake connection to the top of the catch can connection. I have never seen 3 hoses coming of any ones catch can but mine! Is this right or wrong? Is this why I now have a vacum leak issues going off and on?
Old Feb 25, 2012 | 11:30 PM
C6LS3's Avatar
C6LS3
i only have 2 hoses on mine.
Old Feb 26, 2012 | 10:34 AM
haljensen's Avatar
haljensen
The catch can should only be on the line from the valley cover to behind the throttle body. The other line from the valve cover to in front of the throttle body is a separate circuit for make up fresh air into the crankcase.
Plug the additional line and run just the one from the valley cover to behind the throttle body.
Old Feb 26, 2012 | 11:21 AM
Mattraffai's Avatar
Mattraffai
We actually have both valve covers breather holes going to catch can lines he just t'd into the passenger valve cover so not to have 4 connections. so should i plug the drivers side valve cover as well?
Old Feb 26, 2012 | 12:16 PM
Mattraffai's Avatar
Mattraffai
we also deleted that hose line that snaped into the maf boot going back towards one of the engine connections
Old Feb 26, 2012 | 01:00 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
as stated one line in and one line out
clean air return is through the valve covers
Old Feb 26, 2012 | 05:07 PM
Mattraffai's Avatar
Mattraffai
so the intake manifold is the "inlet" and the valley cover is the "outlet" ?
And am i suppose to cap off both valve cover holes with vacuum caps or add breather just to one side or both sides?
Old Feb 26, 2012 | 05:10 PM
Mattraffai's Avatar
Mattraffai
but then there would be two valve covers to plug up because the third line is T'd into catch can and one of the vacuum lines and the valve cover.
Old Feb 26, 2012 | 06:16 PM
haljensen's Avatar
haljensen
Stock there is one line from the passenger side valve cover to in front of the TB, that line allows filtered air to enter the crankcase and one line from the valley cover to behind the TB, that line allows excess pressure (and oil fumes) flow from the crankcase to the intake manifold.
Two separate circuits. Valve cover line allows air in, valley cover allows pressure out.
Old Feb 26, 2012 | 09:55 PM
VET4LES's Avatar
VET4LES
Old Feb 26, 2012 | 11:06 PM
99blancoss's Avatar
099blancoss
Former Vendor
Yes the direction of flow is from valley pan to intake.. your putting the can in the middle of that to clean the air flow...
the valve covers are the source of clean air for the crank case... You need flow in one direction to properly evacuate it.
You can use breather on the valve covers or use the clean air return system the way is was supposed to be used. It draws clean air from a line off the valve cover to the intake tract somewhere.. it needs to be filtered air so it comes after the air cleaner.... If you put a check valve in that line you will take care of any reversion that might try to happen.
Old Feb 27, 2012 | 09:31 AM
haljensen's Avatar
haljensen
Don't cap both valve cover lines. You need a source of fresh, filtered air for the crankcase. The two lines work together to keep crankcase pressure neutral. The catch can line relieves over pressure from blowby and the valve cover line relieves negative pressure (vacuum).
Don't put a "breather" on either valve cover line, you'll fail the visible inspection. Cap one and run the other to after the air filter /before the throttle body.
Old Feb 27, 2012 | 05:44 PM
superscout03's Avatar
superscout03
here i just drew this, hope it helps
Old Feb 27, 2012 | 08:34 PM
Mattraffai's Avatar
Mattraffai
Ok i get it now. So what do i do to tap into the maf and tb boot to connect that hose back on to the system. I acciddently threw away the old plastic line from tb to valve cover. What could I use to replicate that piece or what is the gm part number for that line to passenger valve cover?
To catch can hose routing
