Straight pipes
Old Feb 27, 2012 | 03:37 PM
mozz51's Avatar
mozz51
Default Straight pipes
I just bought an 05 with the mufflers cut out (straight pipes right to the tail pipes). It sounds like a track car, but won't pass state inspection. I picked up some take-off C6 mufflers with axle pipes to put on. Question: What are the hose fitting tubes coming off the mufflers for?
Old Feb 27, 2012 | 06:59 PM
V8ANGER's Avatar
V8ANGER
Sounds like you got yourself the valved mufflers. They are vacuum controlled to switch back and forth from straight pipe to muffled.
Old Feb 27, 2012 | 07:05 PM
mozz51's Avatar
mozz51
The mufflers are off a 2008. Did they have the valved mufflers then? I wondered if the tubes were for some kind of 02 sensor or something?
Old Feb 27, 2012 | 07:16 PM
V8ANGER's Avatar
V8ANGER
Came out in 08 models. Look in one of the tail pipes should have a butterfly valve. One in each. With them open they're loud, closed they are quiet.
Old Feb 28, 2012 | 11:02 AM
mozz51's Avatar
mozz51
Thanks for taking time to share you knowledge with me on this. I'll check it out and figure out how to hook it up.
Old Feb 28, 2012 | 12:54 PM
V8ANGER's Avatar
V8ANGER
Since you don't have the 08 model with the factory connections you should look into B&B's vacuum module they use for their systems. It's fairly simple to hook up. Costs around 200 too. I got it on my car with their Fusion system.
Old Feb 29, 2012 | 12:22 PM
mozz51's Avatar
mozz51
Thanks for the info on that. When I recover from buying the car I'll look into it. For right now I'm just going to have the mufflers put on so I can drive it.
To Straight pipes
