no fobs detected
Old Feb 27, 2012 | 11:48 PM
Bryan May's Avatar
Bryan May
Default no fobs detected
I am having some bother with the no fobs detected message in my 2007 C6.
Have changed battery in fob and tried the the turning the key in the boot thing to get the car to recognise the fob, will allow entry but no start unless fob is in glove compartment.
anyone got a solution for me?
Old Feb 28, 2012 | 12:23 AM
Vette_DD's Avatar
Vette_DD
Same as what I posted in C6 General.
http://forums.corvetteforum.com/1580133253-post2.html
Old Feb 28, 2012 | 11:26 AM
FRDnemesis's Avatar
FRDnemesis
I get that occasionally if I lay my fob near my cell phone in the car.
Old Feb 28, 2012 | 01:15 PM
Bryan May's Avatar
Bryan May
Yup i have been told that and is not the case at the moment, but will remember that -thanks
Old Feb 28, 2012 | 01:38 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
If it is not interference, chargers, phones, electronic devices, then the fact that you can only get the FOB recognized in the glove box slot says:
FOB battery is bad. (Battery put in backwards or used the crosshatched one that won't make proper contact)
FOB is bad
BCM receiver is bad
Turning the key isn't doing jack for you, so don't do it unless you want to reprogram the FOB
Elmer
Old Feb 28, 2012 | 01:51 PM
Bryan May's Avatar
Bryan May
thanks, will try new fob battery and get car battery tested although it shows green status.
Bryan
Old Feb 28, 2012 | 02:10 PM
eboggs_jkvl
Moderator emeritus
Bryan
The car starts, right? I doubt the car battery is the issue. The FOB, the FOB receiver, or there is interference inside the cabin that is "hiding" the FOB from the receiver.
Elmer
Old Feb 28, 2012 | 02:21 PM
Bryan May's Avatar
Bryan May
Hi Elmer, car starts no prob, will get a panasonic battery for the fob, there are no known electronics in or around the car.
Bryan
Old Feb 28, 2012 | 05:33 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
I have the same issue with my '08. Will only start with fob in glovebox slot. It happened after I disconnect the car battery while I installed my cam. Replaced the fob batteries, didn't help. Think it may need a trip to the dealer. Keep us posted on how you make out.
Old Feb 28, 2012 | 06:44 PM
Bryan May's Avatar
Bryan May
Thanks, will do
Old Feb 28, 2012 | 07:22 PM
ROD BROWN's Avatar
ROD BROWN
Default No Fob Dected
Hi,I took my 09 Vette in to the dealer ship for the same reason.The tech said the fobs were ok.The tech stated the battery in the car was kaput and replaced the car battery.Worked fine until I went to Hooters and when I left I got the same old thing.No Fobs detected.Waste of time so I am going back to the dealer and let them play with my car.
Old Feb 28, 2012 | 08:15 PM
Bryan May's Avatar
Bryan May
remind me not to go to Hooters
Old Feb 28, 2012 | 08:24 PM
Bryan May's Avatar
Bryan May
Ok, things i have tried - Disconnected battery for 20 mins.
Put new Panasonic batteries in fobs 1 and 2
Checked for electronic devices in and around car - nothing - (my other 2008 corvette is in next garage bay and starts fine)
Car battery i showing 13.9 volts and is green status indicator.
Read Manual cover to cover.
Note also the trunk wont open unless with key or drivers switch and fob manual lock, unlock and horn button on fob does not work on either remotes.
Any more suggestions ?
Old Feb 28, 2012 | 10:00 PM
eboggs_jkvl
Moderator emeritus
Time for the dealer and the receiver.
Old Mar 13, 2012 | 10:22 PM
Bryan May's Avatar
Bryan May
Ok Problem sorted, probs started when the car battery went flat, last thing to do was to change battery and reprogram FOBS as the car "forgot" them, had a Techo go over the car and plug in the analiser just in case, all good now.
Thank you guys for you input.
To no fobs detected
