A6 shifter removal help needed!
Old Mar 6, 2012 | 02:13 PM
Goatdad's Avatar
Goatdad
St. Jude Donor '11-'12-'13
Default A6 shifter removal help needed!
Can anyone tell me how to disconnect the shifter assembly from the linkage?
I have the console torn down and the shifter unbolted but when I lift it it is (obviously) still connected to the linkage by a ball joint or something. Not much room to move around without damaging something. Is it a ball joint that I can pry apart? special tool needed?
Thanks in advance for the.help.
Old Mar 6, 2012 | 04:15 PM
Goatdad's Avatar
Goatdad
Got it. Lift assembly and gently twist clockwise. Bingo!
Old Mar 6, 2012 | 08:02 PM
S'vette's Avatar
S'vette
It was a pain for me too. You have to have the twist degree just right to get it off. Once youre there its a piece of cake as you found out. You do the DSV replacement?
Old Mar 6, 2012 | 08:42 PM
Goatdad's Avatar
Goatdad
It snapped back together fairly easy too!
Haven't done the DSV upgrade yet but now that I can get it done in a half hr or less its on top of my list. I'll spend what I saved fixing the shifter.
Old Jun 9, 2014 | 08:05 PM
bjphio's Avatar
bjphio
I have to make the same repair and am wondering what the connection actually is between the control and the transmission cable.
Old Jun 9, 2014 | 10:02 PM
RicK T's Avatar
RicK T
Found this one with a pic of the shifter end of the cable. Don't know if it tells you enough though:
http://forums.corvetteforum.com/c6-c...ift-cable.html
To A6 shifter removal help needed!
