GM Hot Cam
Old Mar 8, 2012 | 07:29 PM
grady's Avatar
grady
Default GM Hot Cam
Anyone install an LS2/LS3 GM Hot Cam. If so, was it worth it?
Old Mar 8, 2012 | 07:54 PM
mad11C6's Avatar
mad11C6
Subscribed.
Old Mar 8, 2012 | 08:48 PM
CDaniel525's Avatar
CDaniel525
I think the general consensus is the HOTCAM is very mild compared to most of the cams out there currently and doesnt make near as much power as one would generally be looking for.
IE, I went with a custom grind Pat G cam 231/238 .617/.615 113+2 and made 487/445 at the wheels and the cam is extremely streetable! Search for some results results for the HOTCAM
Old Mar 9, 2012 | 04:36 PM
mad11C6's Avatar
mad11C6
I'm not sure if this is the OP's intent, but I would be interested even if it only made a "less than stellar" amount of HP, but was more than factory and was covered by warranty since it is a GM product. Is that the case here?
Old Mar 9, 2012 | 05:17 PM
grady's Avatar
grady
I know the CAM is a mild one but I would suspect it is because it works within GM's specs with the stock heads and no additional tuning. Basically pull the stock one out and replace it with the hot cam and go. No worrying about new rods, springs, rockers and tuning.
GM claims a 50 hp increase but if it takes <10 install time @ $100/hour seems like $30/hp which is not too bad if you are looking for better performance but not being able to beat everyone you encounter.
Old Mar 9, 2012 | 05:20 PM
S'vette's Avatar
S'vette
Do you get any surging or bucking or hard cold starts?
Old Mar 9, 2012 | 05:23 PM
Bill Dearborn's Avatar
Bill Dearborn
Not covered by the warranty. That part is a GMPP part and its use can invalidate warranty claims.
Bill
Old Mar 9, 2012 | 05:27 PM
S'vette's Avatar
S'vette
How do they call it a mild cam and say it gets an extra 50 hp with no tuning? Must be at the flywheel and not the rear wheels.
Old Mar 9, 2012 | 05:46 PM
mad11C6's Avatar
mad11C6
Bill
Thought it was too good to be true!
Funny, GM product but installing it on your GM vehicle voids your GM warranty.
Old Mar 9, 2012 | 06:34 PM
CDaniel525's Avatar
CDaniel525
Bill
Ive found the bucking/surging to be non-existent pretty much every where in RPM and the one time I felt it, it was hardly noticeable...
No cold hard start issues either.
Old Mar 9, 2012 | 08:13 PM
S'vette's Avatar
S'vette
Thats good, I would have thought to get that high in the rwhp there would be some. Do you have a auto or manual? And would having that same cam inan auto make a difference with surging? Thanks.
Old Mar 9, 2012 | 08:41 PM
CDaniel525's Avatar
CDaniel525
Nope, plenty of guys in that HP range and even a little bit more with hardly any driveability issues! I have a manual, so not sure how it would be in an auto, but cant imagine itd be any different?
Old Mar 10, 2012 | 05:25 PM
rayk's Avatar
rayk
I'm looking at doing the Hot Cam. Did you dyno before and after?
Did you do it yourself? Any issues?
Old Mar 10, 2012 | 06:45 PM
grady's Avatar
grady
No I didn't (yet). I was looking at a supporting vendors site and came across the part for $399. Description is 50 FLYWHEEL horsepower increase to 480 from 430 in the LS3.
I don't know how long it takes to install but if $1000 then <$1500 for 50 hp. Sure it isn't the greatest cam but if you want better performance and not needing to beat everyone you encounter this may be a way to go. I know I am looking into it.
Old Mar 10, 2012 | 10:04 PM
S'vette's Avatar
S'vette
50 hp even to the fly has to be tuned or I cant see it getting that much and keeping good driveability or even just good mpg etc. They may have a canned tune they put in too and we just dont know it.
Old Mar 11, 2012 | 04:21 AM
filmjay's Avatar
filmjay
St. Jude Donor '10
It will void a warranty, and there are vastly superior cams available.
Old Mar 11, 2012 | 09:52 AM
CDaniel525's Avatar
CDaniel525
To GM Hot Cam
