Fast 102 Intake Install questions
Old Mar 10, 2012 | 01:16 PM
chpdbp's Avatar
chpdbp
Default Fast 102 Intake Install questions
Just took it out of the box and need some help. The instructions are not exclusively for the LS2, which I have but for the other 15,000 vehicles you can use it on. So here are my issues. 1) Do I need to take the upper & lower shells apart and RTV the rear seal area when I put it back together? 2) Which MAP sensor does the LS2 have grommet or O ring, does it get mounted front or rear? 3) Is the EGR hole in the front , in front of the LSX lettering get used or not? Thanks for any help, I wish the instructions were specific for the engine application.
Old Mar 10, 2012 | 04:32 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
1) Do I need to take the upper & lower shells apart and RTV the rear seal area when I put it back together? No need to separate it.
2) Which MAP sensor does the LS2 have grommet or O ring, does it get mounted front or rear? Grommet, front.
3) Is the EGR hole in the front , in front of the LSX lettering get used or not? You don't have EGR so not used.
It's a great mod. You will be very happy.
Old Mar 10, 2012 | 07:54 PM
chpdbp's Avatar
chpdbp
Thank you. I collected my thoughts and went back out & looked at it a bit more. I appreciate your response. It makes a lot more sense now. I was getting befuddled with the additional intructions for C5's and earlier model Camaro's mixed in with C6's.
To Fast 102 Intake Install questions
