What size are your pushrods?
Old Mar 10, 2012 | 03:05 PM
starchedup's Avatar
starchedup
Default What size are your pushrods?
I'm curious what size pushrods should I have if my heads were Wilkes to .35? Currently I have:
285cc port*
**Milled to .35
**Titanium Intake vales are 2.20
**Stainless Exhaust valves are 1.60
**Push rods length is 7.750 & .310 thick
Are my pushrods too long? Been told should be 7.70 and .3875 thick...
Your thoughts?
Old Mar 10, 2012 | 03:22 PM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Those seem awfully long. Mine are 7.425 11/32" diameter.
Old Mar 10, 2012 | 03:29 PM
starchedup's Avatar
starchedup
Our heads are different (Z06 heads here), does that matter?
Old Mar 10, 2012 | 03:33 PM
JUIC3D's Avatar
JUIC3D
I'm sure it absolutely matters, I just wouldn't have thought it would be a .325" difference.
I'm no expert though so I'm going to respectfully not give my opinion on the matter as I'd hate to complicate things. I'll sit back and let the experts chime in
Old Mar 10, 2012 | 04:15 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
You milled the heads, reduce the length of the pushrod.
Stock is 7.8
Current thinking is the bigger the diameter of the pushrod the better. If you can fit a 3/8" rod in the head, use it, if not, a 5/16" or drill the PR hole larger if possible.
You really should use an adjustable PR to measure the length needed, there are too many variables that effect PR length.
Old Mar 10, 2012 | 04:27 PM
DSOMC6's Avatar
DSOMC6
An adjustable pr length checker and some dykem will give you the correct pr length.
To What size are your pushrods?
