2 OEM Tunnel plates??
Old Mar 14, 2012 | 02:37 AM
stevette17's Avatar
stevette17
Default 2 OEM Tunnel plates??
If the factory tunnel plates are 1/4" thick why not double up on them instead of buying a 3/8" one?
thanks
Old Mar 14, 2012 | 08:10 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
thanks
The OEM plates are .120". doubling them would be about the same as a 1/4" aftermarket.
Old Mar 14, 2012 | 01:24 PM
Don 79 TA's Avatar
Don 79 TA
Hmmmnnn
not sure if there would be a gapping issue or not
but if you want to try, i have one i am trying to sell
those bolts are long though
not sure if clearance might be an issue with some exhaust pipes
Old Mar 14, 2012 | 01:44 PM
Bill Dearborn's Avatar
Bill Dearborn
Not sure how much a thicker plate does on a C6. There was some benefit to going with a thicker plate on a C5 and the factory incorporated thicker plates into the C6. If it would have helped to increase the thickness more than they did they could have easily done that.
Bill
Old Mar 14, 2012 | 03:35 PM
stevette17's Avatar
stevette17
i have a vert so figured it will help more than a non vert
Old Mar 14, 2012 | 09:51 PM
thedigitel's Avatar
thedigitel
I was wondering about this as well. I'd think 2 OEM plates bolted up would be just as good as an aftermarket 1/4" plate. Anyone done this?
Old Mar 14, 2012 | 09:55 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
dont know where, so i guess im just spreading rumors, but i read somewhere that said thicker tunnel plates stiffen the car in all the wrong places.
Old Mar 15, 2012 | 07:52 AM
davekp78's Avatar
davekp78
I did it. I also added a 1/8" spacer between the two OEM plates for even more rigidity. Didn't notice any real change but I don't drive very hard.
Old Mar 15, 2012 | 07:55 AM
davekp78's Avatar
davekp78
The tunnel plates don't affect the chassis or suspension at all but they may reduce body flexing.
Old Mar 15, 2012 | 11:07 AM
HOXXOH's Avatar
HOXXOH
Best move right there. But not necessarily for the right reason. The space between the plates allows additional airflow and twice the surface area to provide more cooling, which is a main reason for the plate. Without a plate, the exhaust pipes would not only heat up the interior beyond belief, but also heat the torque tube, automatic transmission fluid lines, and fuel lines.
Considering the size of the holes, the low torque specs on the small bolts, and the thinness of the attachment flange, the plate itself has minimal structural benefit.
Old Mar 15, 2012 | 11:24 AM
timd38's Avatar
timd38
I did the ceramic coated aluminum plate that is 3/8" and the tunnel is cooler and when I jack it, there is less flex.
It was only $100 shipped, but the guy went out of business..........
Old Mar 15, 2012 | 07:24 PM
AYello1's Avatar
AYello1
Sandwiching two plates together sounds like a good reciept for a buzzing type of rattle.
Old Mar 16, 2012 | 08:40 AM
davekp78's Avatar
davekp78
Why?
To 2 OEM Tunnel plates??
