Service Electrical system
Old Mar 14, 2012 | 01:45 PM
Mattraffai's Avatar
Mattraffai
Default Service Electrical system
I keep getting Service electrical system this on the dic display. First it said scs (service charging system) then i replaced the sparks plugs and wires it hasn't came back and it's been 3 months now. Well now my horn blew the other day and the fuse is ok but it just makes a loud clicking sound instead of honking. Yesterady my electric water pump 20amp in line fuse blew twice in 5 min and now its fine and not blowing at all. But now a service electrical system is coming on now as much as 5 times a minute to once in 5 minutes but it is constant doing bleeping. I had alt and battery checked and there fine. i couldn't find what appeared to be any corrosion on anything or shorts. the volts do drop down as low 11.9-12.9 alot when i come to a stop ( I always thought it was big cam car with stock converter)but then it reads 13.5-14.5 when the car starts moving and never has anything come up once car is rolling.can my 25% ud pulley have any effect in power changes when the car stops?
