Will trick flow heads 245 fit 06 ls2?
Old Mar 14, 2012 | 09:47 PM
vipercupp's Avatar
vipercupp
Default Will trick flow heads 245 fit 06 ls2?
Looking at these heads but not sure if they fit my 06 ls2 they are trick flow 245s says bore has to be 4.030 or bigger
Old Mar 14, 2012 | 10:28 PM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
Go thirty over and they'll "fit", technically. That's a huge head, however, and would be much more suited to big stroker builds.
TF225's are your best option for a stock cube 6.0 for overall power.
Old Mar 14, 2012 | 10:46 PM
vipercupp's Avatar
vipercupp
I could just get a good deal on the 245s was hoping they would work my car is twin turbo now
Old Mar 14, 2012 | 10:52 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
TF225's and the G6x3 is a 500+rwhp machine. Tried and true.
Old Mar 14, 2012 | 11:23 PM
vipercupp's Avatar
vipercupp
I'm close to 600rwhp now wantn to do heads now
Old Mar 14, 2012 | 11:35 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Oh.
If you posted your current mods you would get responses that are more on point.
Old Mar 15, 2012 | 01:08 AM
vipercupp's Avatar
vipercupp
Originally Posted by Joe_G
Oh.
My question was on point just asking if 245s would fit my ls2 has nothing to do with how much Hp I'm making or other mods I have.
Old Mar 15, 2012 | 02:38 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I think Joe_G was just saying that with an accurate listing of your mods it would be easier for others to provide appropriate feedback on the 245 heads for your intended application.
San
Old Mar 15, 2012 | 03:01 AM
LS1LT1's Avatar
LS1LT1
Actually, it does.
But to answer your question in the most simple/direct way, yes, TFS 245s will fit on to an LS2 bottom end.
Old Mar 15, 2012 | 12:48 PM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
You didn't mention your car was a 600rwhp twin turbo job. That obviously DOES have bearing on whether or not 245's work for your application. If you think it doesn't, then you're in over your head- seeing as you did need to seek help for rather basic info. Posting more context will beget more calibrated, precise responses.
Stock short block or is your bottom end forged? What compression are you running / intend to be running? Swapping heads will also change your compression depending on application, which may or may not be beneficial to your setup.
Again, more context. "Fitting" rarely ever means "functioning" in the automotive world. Just because it bolts on doesn't mean works.
Old Mar 15, 2012 | 10:42 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Another hot tip.
If you are asking people for help, be nice to them. Don't belittle them. You will tend to reap what you sow.
Works great for me.
Old Mar 16, 2012 | 01:12 AM
vipercupp's Avatar
vipercupp
That wasn't my intention. Just Askn a ?. Thanks for the help
Old Mar 16, 2012 | 01:33 AM
vipercupp's Avatar
vipercupp
My car is a APS twin turbo stock bottom end running 10lbs of boost. I wasn't wanting to lower compression alittle to maybe run few more pounds of boost. Would like to get to 650-700rwhp. Just wasn't sure if the 245s would work for me or should I pass on them an get 225s.
Old Mar 16, 2012 | 05:34 AM
camirocz's Avatar
camirocz
And i think Slick Shoes was a little rude in answering the op!
Old Mar 16, 2012 | 01:26 PM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
Rude? Somebody needs a nap and a warm bottle.
Old Mar 21, 2012 | 11:36 AM
TrickFlowTech's Avatar
TrickFlowTech
Supporting Vendor
The 245cc head will fit the stock bore but it will shroud the chamber just a hair. You will need to run the bigger bore gaskets to clear the chamber as well.
Old Mar 22, 2012 | 09:43 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Trickflowtech;
Tell us about the proper usage of 225, 235, and 245 heads as they relate to both the LS2 and LS3 engines. What are their advantages and under what conditions of bore and valve train?
To Will trick flow heads 245 fit 06 ls2?
Old Mar 22, 2012 | 11:06 AM
TrickFlowTech
Supporting Vendor
Originally Posted by jim2092
Trickflowtech;
Well that is a hard question to completely answer. The heads will fit many combinations and depending on the giving combination would determine which head would be recommended.
For example on the combination in this thread a Twin Turbo LS2 you can use either of the 3 heads and get different results and different purposes. If you are looking for a max effort build and trying to make as much HP as possible the 245 head even though it shrouds the chamber a little bit would be the head of choice and same coule be said for the 235cc head. This would also be determined if the engine has be stroked. A large cubic inch, twin type build it would be a no brainer to go with the bigger runner head to allow for the proper volume needed to move the air that the bigger cubed motor would require.
On a stock LS2 naturally aspirated combination I would lean towards the 225 or 235cc head but that would also depend on use of the vehicle. A daily driver I would lean more towards a 225cc head but for a drag race application I would probably recommend a 235cc head.
I hope this helps a little.
Old Mar 22, 2012 | 11:38 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
[snip]
^^ It shows how important it is to properly frame a question if you would like relevant answers.
Old Nov 1, 2012 | 11:52 AM
CandyRedDevil's Avatar
CandyRedDevil
245cc's on a stock ls3?? pros/cons
