Screaching sound when brakes need replacement?
Old Mar 19, 2012 | 02:08 PM
Maites's Avatar
Maites
Default Screaching sound when brakes need replacement?
I have been hearing a screaching sound lately when driving. Noise comes and goes but you can hear it when you apply brakes AND while coasting. Only time I dont hear it is at idle. The shop told me i just need a new set of rear pads. Seem right? This screaching sound sucks.
I have been told I only need need rear pad replacement. Anyone have a set they would reccomend? Don't need any crazy perfomance pads but i do want decent stopping power. Keys for me are quiet and low dust as well.
Thanks to all!
Old Mar 19, 2012 | 07:20 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I went with GM Ceramics a couple of years ago and have been entirely satisfied. No more dust and they are quiet. You can buy a full set from Gene at GMPartsHouse.com for about $150.
Old Mar 19, 2012 | 07:29 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If you change the types of pads, be sure to change them all the way around to the same time, same time. As stated, the ceramics are nice.
Old Mar 19, 2012 | 07:46 PM
DSOMC6's Avatar
DSOMC6
If you are only replacing the rear pads I would install the same pads as you have in the front. Mis-matched pads are not the best idea.
Most replace both front and back when changing/upgrading brake pads on a street driven C6.
I prefer to spend a little more for a quality break pad. For the street Carbotech bobcats work awesome, create minimum dust and are easy on rotor wear.
Old Mar 19, 2012 | 08:39 PM
Maites's Avatar
Maites
thanks guys. I guess I just always figured it was probably better to go after market assuming gm parts are more expensive and not always as good quality.
Old Mar 19, 2012 | 09:49 PM
Maites's Avatar
Maites
BTW my dealer quoted me 225 to replace rear pads and "machine" the rotors.....fair?
Old Mar 20, 2012 | 12:26 AM
Bill Dearborn's Avatar
Bill Dearborn
If you just replace the pads with the same brand and compound that is already on the car there really isn't a need to turn the rotor unless it is damaged. If you turn the rotor it will take a little while for the new pads to build up the transfer layer to the same point it was before the rotor was turned.
Dealer price for the pads can be more expensive than if you get the from one of the forum vendors that sell GM Parts. The correct GM pad replacement kit will come with new pads and new caliper hardware (abutment plates and pad retaining spring and new caliper guide pin bolts). If you go with aftermarket pads you wil have to resuse the old hardware or buy it. That is one of the reasons for the price differential between GM and aftermarket replacement pad kits.
Here is a link to the GM Parts House pricing:
http://store.gmpartshouse.com/parts/...icleid=1432739
If you decide to change the type of pad you are using you should change the pads at all 4 wheels to keep the brake system balanced.
Bill
Old Mar 20, 2012 | 08:33 AM
Maites's Avatar
Maites
Does $225 seem like a fair price? Should I ask them to leave the rotors alone unless they can show me how they are damaged? At this point, seems like I just go with the OEM part.
Old Mar 20, 2012 | 08:50 AM
Dragracer_Art's Avatar
Dragracer_Art
I'll be keeping an eye on this thread... since my '05 base just started squealing like a pig. Every time I touch the pedal I hear it from both ends of the car. Pads have plenty of life left in them though, so I'm not sure why they are squealing so bad.
Old Mar 20, 2012 | 08:57 AM
speedraider's Avatar
speedraider
Have you taken the wheel off and looked at the brake pads yourself? How many miles on the pads?
Old Mar 20, 2012 | 03:32 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Thanks to all!
When did you change the fronts? as most of the braking is done on the front of these cars.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Mar 20, 2012 | 11:01 PM
Maites's Avatar
Maites
car has 63k and im not sure when both fronts and rears were changed. According to the tech at the dealer, my fronts were fine. I guess I just don't understand why i would hear this noise when im not on the brake? dealer said it does that to warn you that its time to change.....seems odd? Also, it looks like brake pads are around $110 or $120 o gm parts house. That is for one pad or a set?
Sorry for all the questions. I called another deal today to ask what they would charge for rear brake replacement and they said $430...I have no clue what a fair price is at this pt. Thoughts?
Thanks again all
Old Mar 20, 2012 | 11:24 PM
VetteTrpr's Avatar
VetteTrpr
For $ 430.00 you better be getting rear brakes/pads and rotors, if not run and dont look back..............................
Old Mar 21, 2012 | 01:01 AM
Bill Dearborn
If you push harder on the pedal when you are making a sudden stop do the brakes squeal or do they squeal when you are easily pulling up to a stop sign or traffic light? If they don't squeal when you are pushing the pedal harder then drive deeper and stop harder at planned stops to get rid of the squeal.
Right rear aftermarket pad on my Z06 squeals like a stuck pig if I just breathe my foot across the brake pedal but if I drive at speed 20 or 30 ft closer and then hit the brake there is no squeal.
The OP is getting squeal when his foot isn't on the brake which is an indication the pad wear sensors are touching the rotor.
Bill
Old Mar 21, 2012 | 09:24 AM
speedraider
Thanks again all
If you were here in Orlando, I would do them for free. $430 is plain BS just for the rear, hell its only 30 minutes of work.
Old Mar 21, 2012 | 08:52 PM
Dragracer_Art
Bill
My noise is definitely dependent on pedal effort. I can make the noise go away by changing how I press on the pedal... but in my opinion, I shouldn't have to do that. The brakes are not supposed to squeal.
Old Mar 25, 2012 | 10:31 PM
Maites's Avatar
Maites
i went ahead and bought the pads from GM Parts house. Gene sent them immediately and I am hoping to have them installed tomorrow. My dealer told me their cost was around 180 per pad, i got both for $95 from Gene. Dealers are thieves. I guess I'll just go to a local shop for the work. I was told to machine the rotors for the new pads so i have a clean surface. Thoughts on pad install pricing with the rotor work?
Old Mar 26, 2012 | 03:51 PM
Maites's Avatar
Maites
Finally got everything done. Spent $105 on brake pads from GM Parts House (Gene shipped them out instantly) then spent additional $118 for install and machine rotors. $223 total for the rears.....way better than $430 from the stupid dealers
Old Apr 17, 2012 | 09:20 PM
Licit's Avatar
Licit
I was searching for typical brake pad life and found this thread. That price doesn't sound too bad, especially to get rid of any squealing.
To Screaching sound when brakes need replacement?
