Cheap "Man Switch" Mod
Old Apr 4, 2012 | 05:39 PM
Bedouin's Avatar
Bedouin
Default NPP on/off switch install
I reviewed these NPP switch mods carefully & it looks straightforward. I've a '12 Grandsport with NPP, & no heated seats or other electrical accessories, so I used an add-a-switch in the NPP slot & wired it to a single (2 posts) micro-rocker switch. It took about an hour to get it all installed & it works great.
Old Apr 10, 2012 | 02:30 AM
Guinzu's Avatar
Guinzu
Saw this post, did this mod. I like this vs having an extra FOB. Thanks a bunch!
Old Apr 10, 2012 | 02:58 AM
JCtx's Avatar
JCtx
Originally Posted by Nate_M
the reason I didn't do the fuse tap from the seat heater is mine is already being used for iPod intergration.
No need to use the heated seat circuit at all folks; ECU cuts power to the valves (opening them) AFTER the fusebox, as I said earlier. Therefore, I redid my installation the other day the proper way. And no need to go thru the trouble of wiring leads to a blown fuse either, and then add an unsightly fuse holder. Wiring an NPP switch using only the NPP fuse slot is very easy, neat, cheap, fully reversible in a minute, and the circuit is protected by the same 10A NPP fuse. If you already have the NPP switch wired to the heated seat circuit, it takes you a minute to rewire it this way. The only difference is the 'add-a-fuse' just has to be rotated 180º (see pic below). The NPP terminal you use to connect the switch is the LEFT one in front of the fuse (not visible in the pic since the fuse is hiding it). And yes, the right terminal in front of the fuse should also be empty. So basically we're converting the 'add-a-fuse' into an 'add-a-switch'... and you can do that with any dedicated fuse you want . Very neat installation, switch looks factory, and quicker than fumbling with a remote, plus no batteries to change ever. Hope this helps folks. By the way, this was done to my '12 GS CE, but all Vettes with NPP are the same.
Old Apr 10, 2012 | 06:04 AM
Nate_M's Avatar
Nate_M
Glad it worked out for ya!
Old Apr 17, 2012 | 07:23 PM
Bedouin's Avatar
Bedouin
Yep, can't recommend this enough & it's really straightforward. I'm surpised how often I switch the npp on/off depending on how & where I'm driving.
Old Apr 17, 2012 | 07:38 PM
kctay's Avatar
kctay
Very nice!
Old Apr 17, 2012 | 09:34 PM
Nate_M's Avatar
Nate_M
Old Apr 18, 2012 | 11:36 AM
MIGHTYM0USE's Avatar
MIGHTYM0USE
i have this one (first version of my diy) just laying around if anyone wants it for 10 bux shipped lemme know.
the way its set up both circuits are still fused.
this is how mine is now for show n tell.
Old Apr 18, 2012 | 11:47 AM
Nate_M's Avatar
Nate_M
I REALLY like that one. I'm going to steal it.
Old Apr 18, 2012 | 12:00 PM
kctay's Avatar
kctay
I'll take one of your 'new' versions for $15! Or what's behind Carol Merill at box two!
Old May 1, 2012 | 11:54 AM
Hawkeyevette's Avatar
Hawkeyevette
Nice write up. I have a 2006 vert, does it have a NPP exhaust?
Old May 1, 2012 | 11:58 AM
Nate_M's Avatar
Nate_M
Easy way to check is to see if there are two butterfly valves in the middle two exhaust ports at the tips. If not, then no, you don't.
Old May 1, 2012 | 12:04 PM
  #33
Hawkeyevette
Checked nope there is not. Thanks.
