c-6 instrument cluster
Old Mar 22, 2012 | 09:42 AM
glenn somers's Avatar
glenn somers
Cruising
Default c-6 instrument cluster
I have a c-6 instrument cluster and steering column in a 34 Ford. I also have the complete drive train in it with the corvette wires and e-38 ECM. The harness is a stand alone deal to run the motor only. I am going to attempt to hook the cluster up, however the wires coming out of the cluster plug are cut off at 2 feet. I have tach signal speedo signal coming from the harness, ready to go to the dash.I would like to find a schematic of the cluster and column wireing. color codes etc. so I can hook up what is needed.I am probably going to get a guage controller from painless as some of the wireing did go through the BCM.any help with a wireing diagram would help a bunch.Thanks Glenn
Old Mar 22, 2012 | 10:49 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
I looked in my GM eSi database and thats a lot of systems to go through to try and post. You might be well served to pick up a LSX set of manuals which would have the pinouts, schematics, Etc... that you would be looking for.
Old Mar 22, 2012 | 02:37 PM
glenn somers
Cruising
Default c-6 cluster
Thanks.There are two main plugs that go to the cluster. All have different color wires of course. I was hoping to find for instance if a red with white tracer went to the tach in the cluster, or is it way more that one or two wires feeding a guage.Actually I am looking for what wires in the plug go to what guages. from there I believe i can use the signal wires from my harness for the input to the guages. I have tach signal as well as speedo oil and fuel and water temp.just need to know what wires in the cluster they must go to.
I have never attempted this before. I have a frame building background so I would appreciate any input.I can always go to the aftermarket guages but I like the corvette cluster.Not enough to let it drive me crazy though LOL
Old Mar 22, 2012 | 03:51 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
OK here are the 2 connectors that go to the instrument cluster. See if that helps.
Instrument Panel Cluster (IPC) X1
16 0.35 PK 1691 Low Reference (DD8)
Connector Part Information
OEM: 7283-9076-30
Service: See Catalog
Description: 16-Way F Kaizen 64 Series (BK)
Terminal Part Information
Terminal/Tray: 15359541/4
Core/Insulation Crimp: M/M
Release Tool/Test Probe: 15381651-2/J-35616-64B (L-BU)
Pin Wire Circuit Function
1 0.35 BN/WH 230 Instrument Panel Lamp Dimming Control
2 0.35 BN 1244 Instrument Panel Lamp Supply Voltage - 2
3-4 -- -- Not Used
5 0.35 GY 1036 Class 2 Serial Data
6 -- -- Not Used
7 0.35 TN 470 Low Reference
8 -- -- Not Used
9 0.35 BN 27 Hazard Flasher Signal
10-11 -- -- Not Used
12 0.35 D-BU/WH 1495 Instrument Panel Lamps Dimmer Switch Down Signal
13 0.35 D-GN 44 Instrument Panel Lamps Dimmer Switch Up Signal
14 0.35 PK/BK 1597 Dome Lamp Switch Signal
15 -- -- Not Used
16 0.35 D-GN/WH 357 Oil Temperature Sensor Signal
Document ID: 1897236
Page 140 of 247
http://localhost:9001/si/showDoc.do?docSyskey=1897236&pubCellSysk ey=164814&pub...
3/22/2012
Instrument Panel Cluster (IPC) X2
Intrusion Sensor (UA2)
OEM: 7283-9077-40
Service: 89047195
Description: 16-Way F 64 Series (L-GY)
1 0.5 BK 1450 Ground
2 -- -- Not Used
3 0.5 RD/WH 1140 Battery Positive Voltage
4 -- -- Not Used
5 0.35 WH 121 Engine Speed Signal
6 0.35 D-GN/WH 817 Vehicle Speed Signal
7 0.35 BN 9 Park Lamp Supply Voltage
8 0.35 TN/WH 99 Windshield Washer Fluid Level Sensor Signal
9-13 -- -- Not Used
14 0.35 BN/WH 419 Malfunction Indicator Lamp (MIL) Control
15 0.35 L-BU 1134 Park Brake Switch Signal
16 0.35 PU 333 Brake Fluid Level Sensor Signal
Old Mar 22, 2012 | 05:24 PM
glenn somers
Cruising
Default c-6 cluster
Thanks!! that gave me a ton of info.Got tach and speedo and a few others I can use from that diagram. If I can ask one more favor, there is a third plug on the cluster. It is a ten pin connector that is just to the left and perpindicular to the two main plugs. Hoping that you have a diagram of that too. It should have oil and water temp.
I believe I can figure the column out as it is just mechanical connections for turn signals, headlights.etc. I did get the paddle shifter to work off the steering wheel.Its a 6 speed auto.
Thanks again, this is making this job fun Glenn
To c-6 instrument cluster
