Break in oil?
Old Mar 24, 2012 | 09:57 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default Break in oil?
I was always told not to use synthetic oil for break in. Do are cars really come w/ Mobile 1 or is it a special oil. Are the engines already broke in on a dyno before we get them, I tried the search function w/ no luck ?
Old Mar 24, 2012 | 10:03 PM
VET4LES's Avatar
VET4LES
They come with Mobil 1 5w 20 and it's not a break in oil. Read your manual about breaking it in. I think my 05 said 500 miles but that's not for the engine it's for the gears in the trans and differential. The brakes need breaking in also.
Old Mar 24, 2012 | 10:10 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
From a different thread but on topic.
Originally Posted by glass slipper
Also, your engine would have made 185-190 at 10 miles...there is no break-in for the engine, the rings are seated by the time you pick your car up. That's the result of GM using moly rings with a plateau finish honing process...they've been doing it that way for many years. The break-in is mainly for the ring and pinion, brakes, and somewhat for the transmission.
San
Old Mar 24, 2012 | 10:18 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Thank-you San, so that implies that the new ring technology breaks in very quickly, or the engines are run on a dyno and pre - broke in. Either way the old advice about break in oil does not seem to apply here!
Old Mar 24, 2012 | 10:22 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
You learn who to listen to and who to ignore on this forum. I listen to glass slipper and I suggest you do as well.
San
Old Mar 25, 2012 | 02:13 AM
Pitbull11's Avatar
Pitbull11
You mean 5w30 not 5w20 right or did they make a change since my 2008 was built?
Old Mar 25, 2012 | 05:20 PM
VET4LES's Avatar
VET4LES
Your right 5w 30 it is. I get confused with my other car which is 0w 20. I change them once a year and have a short memory.
Old Mar 26, 2012 | 01:34 AM
Pitbull11's Avatar
Pitbull11
Thanks for clearing that up. I see you live in San Clemente, I lived there back in 1969 when I was in the Marine Corp. nice place.
Old Mar 26, 2012 | 06:59 AM
VET4LES's Avatar
VET4LES
I can see Camp Talega from my back yard. It's in the far n/e end of Camp Pendleton.
To Break in oil?
